Home » Eclipse Projects » Eclipse Platform » property tester that returns true if a certain file exist on the project
property tester that returns true if a certain file exist on the project [message #325925] Mon, 03 March 2008 08:40 Go to next message
I added a popupmenu and it will only pop out on a project. I added
IProject objectclass.
I wanted also that the popupmenu will only show if my.xml is on that
project.
How will I do that? Is there any existing property tester in eclipse like
jdt.launching.hasNature?
Re: property tester that returns true if a certain file exist on the project [message #325931 is a reply to message #325925] Mon, 03 March 2008 09:30 Go to previous message
I think the last time through this the most effective way to do this was
to set a persistent property on the project if the file exists. That
way you can easily test the property (assuming core expressions) using
existing org.eclipse.core.resources property tester.
The other alternative is to write your own property tester and when the
project is selected, go looking for your file.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Disposing listeners added to Selection service
Next Topic:Subclipse vs. WebDAV support?
Current Time: Mon Dec 01 03:44:39 EST 2025
Powered by FUDForum. Page generated in 0.05562 seconds
