Home » Eclipse Projects » Eclipse Platform » getSelection() returns null
getSelection() returns null [message #325896] Sat, 01 March 2008 19:55 Go to next message
Hi All!
I have some problems with the getSelection() method of the
AbstractPropertySection class:
I have a MultiPage Editor consisting of a GMF based editor and a TextEditor.
Furthermore I'm using the a PropertyPage consisting of multiple
PropertySheets/Sections.
When I select an element in my GMF graph I'm using the following code in the
PropertySheet that appears as default when selecting such an element in the
graph:
StructuredSelection selection = (StructuredSelection) getSelection();
StateEditPart stateEditPart = (StateEditPart) selection.getFirstElement();
State semanticObject = (State) ((Node)
stateEditPart.getModel()).getElement();
This snippet is woking without any problem, but only in the default
PropertySheet (appearing automatically when selecting a "State" element in
my GMF graph).
Whenever I select another PropertySheet in the PropertiesView (I'm using the
above code in all my PropertySheets) the getSe
Re: getSelection() returns null [message #325901 is a reply to message #325896] Sun, 02 March 2008 08:26 Go to previous message
I found my fault... i didnt thought about using the SelectionProvider and
retrieving the current selection in the editor directly from the editor ;-)
Now it's working...
Sorry for the inconvenience
Markus
"Markus Gieser" <markus.gieser@googlemail.com> schrieb im Newsbeitrag
news:fqctta$o7o$1@build.eclipse.org...
> Hi All!
> TextEditor. Furthermore I'm using the a PropertyPage consisting of
> multiple PropertySheets/Sections.
> the PropertySheet that appears as default when selecting such an element
> in the graph:
> my GMF graph).
> the above code in all my PropertySheets) the getSe
Previous Topic:When to use Application with Equinox
Next Topic:ToolItems Width
Current Time: Mon Jul 21 23:56:26 EDT 2025
Powered by FUDForum. Page generated in 0.06752 seconds
