Home » Eclipse Projects » Eclipse Platform » dynamic instanceof
dynamic instanceof [message #325832] Thu, 28 February 2008 08:29 Go to next message
i want to use dynamically instanceof in java. I have a string with the
classname to compare. It is possible to get the instance of the class
over this string dynamically?
Greetings
Re: dynamic instanceof [message #325833 is a reply to message #325832] Thu, 28 February 2008 08:36 Go to previous messageGo to next message
Class.forName().newIntance() but this is a general java beginner
question whereas this forum is about Eclipse Technology
Jörg schrieb:
> Hello,
> Greetings
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: dynamic instanceof [message #325835 is a reply to message #325833] Thu, 28 February 2008 09:07 Go to previous messageGo to next message
ah sorry, i thought it wasn't that easy, cause i searched a little bit
longer. But Class.forName().newIntance() give me a syntax error with
instance of. i had to do this:
if ( Class.forName ( classNameString ).isInstance ( myObject ) )
Thanks for the trouble
> Jörg schrieb:
>> Hello,
>> Greetings
Re: dynamic instanceof [message #325836 is a reply to message #325835] Thu, 28 February 2008 09:16 Go to previous messageGo to next message
ah I thought you wanted to create a new instance from a string. The
below is correct of course.
Tom
>> Jörg schrieb:
>>> Hello,
>>> the classname to compare. It is possible to get the instance of the
>>> class over this string dynamically?
>>> Greetings
Re: dynamic instanceof [message #325838 is a reply to message #325835] Thu, 28 February 2008 10:13 Go to previous message
It would be good if you know which bundle provides this class and use
Bundle.loadClass() instead. If the class in question will always be
available in the same bundle it doesn't matter:)
>> Jörg schrieb:
>>> Hello,
>>> Greetings
Previous Topic:compare: switch used comparer
Next Topic:Command in context menu???
Current Time: Sun Aug 31 23:56:30 EDT 2025
Powered by FUDForum. Page generated in 0.05811 seconds
