Home » Eclipse Projects » Eclipse Platform » activeFocusControlId with detached view
activeFocusControlId with detached view [message #325764] Tue, 26 February 2008 10:13 Go to next message
Hi all,
there seems to be no activeFocusControlId when a view has been detached.
The <activeWhen> expression for my handler looks like
<activeWhen>
<and>
<with variable="activeFocusControlId">
<equals value="graphicalViewer">
</equals>
</with>
<with variable="selection">
<count value="1">
</count>
<iterate>
<adapt type="MyType">
</adapt>
</iterate>
</with>
</and>
</activeWhen>
If the view is attached it works like expected.
This might be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=212292
TIA,
Marco
Re: activeFocusControlId with detached view [message #325773 is a reply to message #325764] Tue, 26 February 2008 10:50 Go to previous messageGo to next message
Marco Lehmann wrote:
> Hi all,
> <activeWhen>
> <and>
> </equals>
> </with>
> <count value="1">
> </count>
> <iterate>
> </adapt>
> </iterate>
> </with>
> </and>
> </activeWhen>
One way to test that would be to pick up a version of 3.4 M5 and see if
you still have the problem, or simply remove your 'with
variable="selection"' clause and see if your handler becomes active when
the focus control is active.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: activeFocusControlId with detached view [message #325779 is a reply to message #325773] Tue, 26 February 2008 14:48 Go to previous messageGo to next message
>> Hi all,
>> <activeWhen>
>> <and>
>> </equals>
>> </with>
>> <count value="1">
>> </count>
>> <iterate>
>> </adapt>
>> </iterate>
>> </with>
>> </and>
>> </activeWhen>
> PW
Thanks for your quick answer.
We are developing against a target platform, which is something between
3.3.0 and 3.3.1.
I debugged the WithExpression and the activeFocusControlId was null. I
will try to setup a target platform with 3.4M5, but this may take
awhile. Are there any plans to fix the bug mentioned above and this one
in 3.3.2?
TIA,
Marco
Re: activeFocusControlId with detached view [message #325801 is a reply to message #325779] Wed, 27 February 2008 09:03 Go to previous message
> 3.3.0 and 3.3.1.
> in 3.3.2?
No, 3.3.2 is pretty well closed (and should be available by the end of Feb).
If your control has focus but the FocusControlSourceProvider is not
providing that variable that's a bug (of some kind). Please open a bug
report at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[Services]
It can't be fixed in 3.3.2 but it should be fixed in 3.4
Later,
PW
Paul Webster
Previous Topic:How to bring to top without activating?
Next Topic:Adding a (text editor) page
Current Time: Thu Jul 17 23:36:31 EDT 2025
Powered by FUDForum. Page generated in 0.28480 seconds
