Home » Eclipse Projects » Eclipse Platform » Save handler when editing files not in workspace using eclipse default editor
Save handler when editing files not in workspace using eclipse default editor [message #325737] Tue, 26 February 2008 04:37 Go to next message
Here's the code that would open an external file (meaning file that does
not exist in my workspace) and then edit it using eclipse default editor.
File fileToOpen = new File("external_file.xml");
if (fileToOpen.exists() && fileToOpen.isFile()) {
IFileStore fileStore =
EFS.getLocalFileSystem().getStore(fileToOpen.toURI());
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
try {
IDE.openEditorOnFileStore( page, fileStore );
} catch ( PartInitException e ) {
//Put your exception handler here if you wish to
} else {
//Do something if the file does not exist
I wanted to execute a code when the user saves the document by ctrl+s or
file->save or by pressing the save icon.
How should I do this?
I tried
editorPart.getEditorSite().getActionBars().setGlobalActionHa ndler(
ActionFactory.SAVE.getId(), myaction );
where myaction is an instance of a class that extends Action class and
override s the run method.
But then the run method will never be executed once the document is saved.
I also believe the resource change listener can't be of help either
because it's would only track down workspace resources.
What should I do? Please enlighten me gurus.
Re: Save handler when editing files not in workspace using eclipse default editor [message #325767 is a reply to message #325737] Tue, 26 February 2008 10:29 Go to previous messageGo to next message
You could add an IExecutionListener to the ICommandService ... when the
save command is executed it fires events. The command id is
org.eclipse.ui.file.save
Check out some of the links in my sig for information on the command
framework.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Save handler when editing files not in workspace using eclipse default edito [message #325788 is a reply to message #325767] Wed, 27 February 2008 00:24 Go to previous messageGo to next message
Thanks Paul.
Adding IExecutionListener to the ICommandService worked. However, clicking
the save icon in the toolbar or clicking file->save menu,
IExecutionListener was not executed.
I read your articles but I still can't find how to fire the codes when i
click save icon in the toolbar or if i click file->save menu.
> framework.
> PW
Re: Save handler when editing files not in workspace using eclipse default edito [message #325789 is a reply to message #325788] Wed, 27 February 2008 01:06 Go to previous messageGo to next message
I also used IHandlerService.activateHandler but still same effect. It
works only when i pressed ctrl+s but won't work if i press the save in
toolbar on on file->save menu.
Re: Save handler when editing files not in workspace using eclipse default edito [message #325790 is a reply to message #325789] Wed, 27 February 2008 03:10 Go to previous messageGo to next message
I tried the codes below
<extension point="org.eclipse.ui.handlers">
<handler commandId="org.eclipse.ui.file.save"
class="org.ui.handler.SaveHandler">
<enabledWhen>
<with variable="activePartId">
<equals
value=" org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part " />
</with>
</enabledWhen>
<activeWhen>
<equals
</with>
</activeWhen>
</handler>
</extension>
But still SaveHandler will only be execute in Ctrl+S. Clicking save icon
or file->save won't execute my code.
Re: Save handler when editing files not in workspace using eclipse default editor [message #325793 is a reply to message #325767] Wed, 27 February 2008 05:53 Go to previous messageGo to next message
I didn't see in the ActionFactory that SAVE was hooked up to a command
like the other actions (in 3.4); might this explain Allan's
difficulties? And if that's the case, seems like a bug. I can help if
you want.
> framework.
> PW
Re: Save handler when editing files not in workspace using eclipse default edito [message #325800 is a reply to message #325788] Wed, 27 February 2008 08:59 Go to previous messageGo to next message
Allan Ramirez wrote:
> Thanks Paul.
> clicking the save icon in the toolbar or clicking file->save menu,
In 3.3 legacy actions (like SAVE) don't fire command execution events
.... only using the keybinding will.
In 3.4 we added extra legacy support so clicking the button should also
fire the same kind of events.
In 3.3 the other way around (in an RCP app, anyway) is to turn the
SaveAction into a handler and make Save in the menu and toolbar a
command contribution.
PW
Paul Webster
Re: Save handler when editing files not in workspace using eclipse default edito [message #325819 is a reply to message #325800] Thu, 28 February 2008 01:24 Go to previous message
Thanks a lot Paul.
>> Thanks Paul.
> PW
Previous Topic:Java editor import/method collapsing
Next Topic:Adding actions to context menu
Current Time: Mon Oct 20 17:48:42 EDT 2025
Powered by FUDForum. Page generated in 0.05998 seconds
