Home » Eclipse Projects » Eclipse Platform » To load, activate the classes from one plugin project into another plugin projec
To load, activate the classes from one plugin project into another plugin projec [message #325729] Tue, 26 February 2008 02:04 Go to next message
Originally posted by: narayan.pawar.gmail.com
Hi all,
The situation i got stuck at is,
i am having one main plugin which needs to use the functionality(classes
and functions) provided by another plugin.Both of these plugin are
exported and are added to Eclipse plugin directory.
Now how can i check
1. whether functionality plugin is present/absent from Main Plugin.
2. If present how to activate and load the classes of that functionality
plugin .
3. How to use functionality into main plugin
PLease help me if there is any workaround for this problem.
Narayan
Re: To load, activate the classes from one plugin project into another plugin projec [message #325750 is a reply to message #325729] Tue, 26 February 2008 08:00 Go to previous message
Narayan,
This whole scenario is what extension points are designed to support.
I'd suggest reading some of the documentation about extension points so
you can exploit them effectively.
Narayan wrote:
> Hi all,
> functionality(classes and functions) provided by another plugin.Both
> of these plugin are exported and are added to Eclipse plugin directory.
> Now how can i check
> functionality plugin .
> Thanks
> Narayan
Previous Topic:Linked text when hovering
Next Topic:JFace VIRTUAL Table Viewer
Current Time: Fri Oct 24 04:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.04105 seconds
