Home » Eclipse Projects » Eclipse Platform » How to bring to top without activating?
How to bring to top without activating? [message #325725] Tue, 26 February 2008 00:51 Go to next message
I am trying to programatically open editors and bring each in turn to the
top without activating them. The key is that my application has the
concept of a main window, and these editors are opening in a second
window. I want to leave focus in the main window so that users can
continue working as these editors are opening. I'm seeing two problems:
1. WorkbenchPage.openEditor is activating the editor even when I specify
activate=false. This happens because of problem 2.
2. WorkbenchPage.bringToTop is always making the editor active because
newPartContainer == activeEditorContainer
This seems like an Eclipse bug that was introduced in 3.3. Does anyone
know what changed and if there is a workaround?
Thanks.
Re: How to bring to top without activating? [message #325766 is a reply to message #325725] Tue, 26 February 2008 10:25 Go to previous messageGo to next message
> specify activate=false. This happens because of problem 2.
It will make it the activeEditor ... which isn't the same as making it
active, the same way when you link with editor and click on an file in
the package explorer, the associated open editor comes to the top ...
but the package explorer is still active.
The bug is bringing to secondary window to the front? and it didn't use
to do this in 3.2?
It always made the new editor the active editor (just not the active part).
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to bring to top without activating? [message #325785 is a reply to message #325766] Tue, 26 February 2008 22:20 Go to previous messageGo to next message
Thanks, Paul. You're right; makeActiveEditor was not the cause of the
bug. We were setting focus somewhere else. If I remove all setFocus
calls and never interact with that window, then it behaves as expected.
However I still have a question about active parts in multi-window
situations.
I get the desired behavior if I bringToTop the editors in window 1 and
have some non-editor part active in window 1. I can interact all I want
in window 2 and bringing the editors to the top in window 1 never steals
focus because newPartContainer != activePartContainer.
On the other hand, I don't get the desired behavior if I do the following:
1. makeActive an editor in window 1
2. setActivePart in window 2 by interacting with it
3. Programatically bringToTop an editor in window 1. At this point,
newPartContainer == activePartContainer. This causes the editor in window
1 to be activated, and thus takes focus from window 2. Is this by design?
Thanks for your help.
Re: How to bring to top without activating? [message #325799 is a reply to message #325785] Wed, 27 February 2008 08:56 Go to previous message
AFAIK that is design intent ... being an IDE and activating and editor
(where the active part was the active editor) will force it to the top.
To be honest we very rarely touch that kind of behaviour (presentation
order of events, etc) these days. I think it would be hard to
distinguish between "just the active editor" which activates and sets
focus and "bring to the top but don't set focus when the active editor
had focus" ... that's a tangled set of events :-)
Later,
PW
Paul Webster
Previous Topic:Using Plug-in properties API?
Next Topic:activeFocusControlId with detached view
Current Time: Sun Nov 09 02:33:48 EST 2025
Powered by FUDForum. Page generated in 0.03579 seconds
