Home » Eclipse Projects » Eclipse Platform » problem in deployed plugin
problem in deployed plugin [message #325668] Mon, 25 February 2008 09:02 Go to next message
I am facing problems in deploying the plugin.The plugin is working fine
when
i run it but the deployed version of the same plugin is behaving strange.
I am running few scripts n fethching the output for further processing.
All the necessary scripts are present in jar file but still i guess the
plugin
is not able to locate the scripts.
here is the error message...
Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
If i remove those scripts n give some hardcoded i/p,its working fine.
so i guess the whole problem lies on placing n finding the location of
scripts.
Can anyone please direct me where should i place those scripts(.sh)?
n where should i mention about them?
Thanks in advance.
Vrushali.
Re: problem in deployed plugin [message #325670 is a reply to message #325668] Mon, 25 February 2008 09:13 Go to previous message
Vrushali,
Where are the scripts now? What does your build.properties look like?
Where in the final jarred plugin do they appear? How are you loading them?
vrush wrote:
> fine when i run it but the deployed version of the same plugin is
> behaving strange.
> the plugin
> scripts.
> Thanks in advance.
> Vrushali.
Previous Topic:[refactoring] questions before implementing my own refactor
Next Topic:Add a cascade menu to a contex menu item
Current Time: Sun Nov 09 14:19:30 EST 2025
Powered by FUDForum. Page generated in 0.04336 seconds
