Home » Eclipse Projects » Eclipse Platform » [refactoring] questions before implementing my own refactor
[refactoring] questions before implementing my own refactor [message #325639] Sun, 24 February 2008 22:16 Go to next message
Hi, all;
I'm implementing an editor that edits xml-formated configuration files
which binding with a compilationunit respectively, now that there're two
editors: Java Source Editor, and my Xml Editor, so there're two kinds of
refactors:
1. refactoring starts from java editor
1.1. refactoring type/package takes my configuration file as
participant by extending org.eclipse.ltk.core.refactoring.renameParticipants
1.2 refactoring fields, how can I take configuration files as the
participants?
2. refactoring starts from xml editor
2.1 refactoring attribute value that maps to the java type, how can I
take java refactor as participant?
2.2 refactoring attribute name that maps to the java type's fields,
how can I take java refactor as participant?
Any clues? Thanks in advance.
Thanks & Best Regards!
Nick
Re: [refactoring] questions before implementing my own refactor [message #325661 is a reply to message #325639] Mon, 25 February 2008 08:29 Go to previous message
If you don't get an answer here, I would also try the eclipse.tools.jdt
newsgroup. They're the heaviest users of the LTK refactoring support.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Eclipse Help System Bug?
Next Topic:problem in deployed plugin
Current Time: Thu Nov 06 07:19:40 EST 2025
Powered by FUDForum. Page generated in 0.03125 seconds
