Home » Eclipse Projects » Eclipse Platform » [DataBinding] JavaBeansObservable not updating
[DataBinding] JavaBeansObservable not updating [message #325566] |
Fri, 22 February 2008 03:37  |
during development with the databinding framework I found a strange
behaviour of the JavaBeansObservable (M20070822-0800):
Suppose we run the following simple code:
ModelBean modelBean = new ModelBean();
ModelBean targetBean = new ModelBean();
IObservableList modelBeanObservableList =
BeansObservables.observeList(Realm.getDefault(), modelBean, "list",
String.class);
IObservableList targetBeanObservableList =
BeansObservables.observeList(Realm.getDefault(), targetBean, "list",
String.class);
DataBindingContext bindingContext = new DataBindingContext();
bindingContext.bindList(targetBeanObservableList, modelBeanObservableList,
null, null);
modelBean.add("Str 1");
modelBean.clear();
targetBean.add("Str 2");
for(Object o : modelBean.getList()){
System.out.println(o);
ModelBean has a simple array list containing strings and clear() resets the
list. Any other modification of the list can be imagined.
One would expect the console to output: "Str2". But surprisingly there is no
output at all - the model was not updated.
When I debugged the code of JavaBeansObservable I found out the place, where
the underlying writeableList is updated:
public void add(int index, Object element) {
wrappedList.add(index, element);
But this line throws an exception (UnsupportedOperationException?) as
wrappedList is not of type ArrayList but Arrays$ArrayList.
I question myself, what did I wrong?
Nice Greetings,
Masroor
Re: [DataBinding] JavaBeansObservable not updating [message #325579 is a reply to message #325566] |
Fri, 22 February 2008 10:38   |
Arrays.asList returns a list that is *backed* by the passed in array.
Since arrays cannot change length, neither can the list. To make the
list fully modifiable, try using an ArrayList with the copy constructor:
list = new ArrayList(Arrays.asList(array));
Matthew
Masroor Ahmad wrote:
> Hello,
> String.class);
> String.class);
> null, null);
> modelBean.clear();
> Nice Greetings,
> Masroor
Re: [DataBinding] JavaBeansObservable not updating [message #325581 is a reply to message #325579] |
Fri, 22 February 2008 11:11   |
Thanks for the reply.
I see, to solve this one has to change API code or subclass.
The original API code:
public class JavaBeanObservableList extends ObservableList implements
IBeanObservable {
updateWrappedList(Arrays.asList(getValues()));
Masroor
> Since arrays cannot change length, neither can the list. To make the list
> Matthew
>> Hello,
>> String.class);
>> String.class);
>> modelBeanObservableList, null, null);
>> modelBean.clear();
>> the list. Any other modification of the list can be imagined.
>> no output at all - the model was not updated.
>> where the underlying writeableList is updated:
>> Nice Greetings,
>> Masroor
Re: [DataBinding] JavaBeansObservable not updating [message #325588 is a reply to message #325585] |
Fri, 22 February 2008 12:09  |
The current version of DataBinding is compatible with Eclipse 3.3. Try
running your app with a recent build of JDB:
http://download.eclipse.org/eclipse/downloads/drops/S-3.4M5- 200802071530/index.php
You should only need to swap in the data binding plugins:
org.eclipse.core.databinding
org.eclipse.core.databinding.beans
org.eclipse.jface.databinding
If the error goes away with the 3.4 build, we'll still want to fix it in
the 3.3 maintenance stream. So please file a bug either way--this test
will just help us determine the scope of the bug.
Matthew
> 1.0.1.M20070910-0800b
> "Matthew Hall" <matthall@woodcraftmill.com> schrieb im Newsbeitrag
> news:fpmt68$t5s$1@build.eclipse.org...
>> I think this was fixed some time ago, possibly after the 3.3 release. What
>> version of DataBinding are you using?
>> Matthew
>>> Roger this. It's the latter case.
>>> Masroor
>>> "Boris Bokowski" <Boris_Bokowski@ca.ibm.com> schrieb im Newsbeitrag
>>> news:fpmqng$fe3$1@build.eclipse.org...
>>>> Arrays.asList() returns an unmodifiable list. The question now is: did
>>>> you create this list, or did the data binding framework do that. If it's
>>>> the former, make sure you use modifiable lists in both model and target.
>>>> If it's the latter, would you mind filing a bug, ideally with an
>>>> attached snippet with which we can reproduce it?
>>>> http://wiki.eclipse.org/Platform_UI/FAQ#How_do_I_report_a_bu g.3F
>>>> Thanks
>>>> Boris
Current Time: Tue Jul 22 15:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.04015 seconds
