Home » Eclipse Projects » Eclipse Platform » TreeViewer text spanning columns
TreeViewer text spanning columns [message #325553] Thu, 21 February 2008 15:29 Go to next message
Originally posted by: automatic.javalobby.org
I've got a TreeViewer with multiple columns. On certain rows I want to have text that spans two or more columns. This is a feature commonly available in Microsoft Excel and Microsoft Word tables.
Here's a primitive example
|This is All columns text that is wider than each column         |
|Two column text         | Col 3  text | Col 4 text  | Col 5 text|
|Col 1 text | Col 2 text | Col 3 text  | Col 4 text  | Col 5 text|
does anyone have a suggestion?
Thanks in advance.
Re: TreeViewer text spanning columns [message #325554 is a reply to message #325553] Thu, 21 February 2008 16:50 Go to previous messageGo to next message
Use nebula-grid.
Tom
> Thanks in advance.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TreeViewer text spanning columns [message #325570 is a reply to message #325554] Fri, 22 February 2008 06:39 Go to previous messageGo to next message
Thanks for the tip. I'll keep an eye on nebula-grid and when it is out of development I'll consider it.
For now, I'll live with what's available.
Re: TreeViewer text spanning columns [message #325571 is a reply to message #325570] Fri, 22 February 2008 06:41 Go to previous message
Well although marked Alpha the widget is fairly stable.
Tom
Previous Topic:using tables in an eclipse form
Next Topic:"The operation is not currently available"
Current Time: Sun Nov 09 04:56:28 EST 2025
Powered by FUDForum. Page generated in 0.05466 seconds
