Home » Eclipse Projects » Eclipse Platform » Wiki update about complex expressions
Wiki update about complex expressions [message #325499] Wed, 20 February 2008 06:15 Go to next message
Originally posted by: jan-hendrik.diederich.bredex.de
The Command Core Expressions explanation on
http://wiki.eclipse.org/Command_Core_Expressions is incomplete. While the
command core expressions support complete complex nested boolean
expressions,
it's never mentioned in a single word or example. You can, to my knowledge
tell me if I'm wrong - insert boolean expressions like "(a & b & (c | d |
(!e)))". But after reading the Wiki you get the impression it's declared
in the
xsd but not officially supported, since also the javadoc in the
corresponding
xsd never mentions it. Referring to the given example above the declaration
would look like this:
<and>
<test args="a" property="rcpAuthActivitiesExample.test1" />
<test args="b" property="rcpAuthActivitiesExample.test2" />
<or>
<test args="c" property="rcpAuthActivitiesExample.test3" />
<test args="d" property="rcpAuthActivitiesExample.test4" />
<not>
<test args="e" property="rcpAuthActivitiesExample.test5" />
</not>
</or>
</and>
(That I took property testers for this example has no special meaning, they
were just very convenient for this example, choose whatever you think fits
better.)
So, is that true that this complex expressions are supported?
If it's true I would really like to update the Wiki, at best with the
example I gave here.
Please answer me, enlightend Eclipse Expression Professionals
Re: Wiki update about complex expressions [message #325541 is a reply to message #325499] Thu, 21 February 2008 11:37 Go to previous messageGo to next message
> expressions,
Just because something is not mentioned in an example doesn't mean that
it is an omission ... but we always welcome new examples that are
descriptive (and work).
> You can, to my
> knowledge -
> in the
> corresponding
The Extension Point Description (and the PDEEditor) give directions on
what is allowed in a core expression. While we welcome more examples,
it's the Extension Point Description (from the exsd) that determines
what is allowed ... why do you assume that the official document that
describes the schema is not officially supported?
> <and>
> <test args="a" property="rcpAuthActivitiesExample.test1" /> <test
> args="b" property="rcpAuthActivitiesExample.test2" /> <or>
> <test args="c" property="rcpAuthActivitiesExample.test3" /> <test
> args="d" property="rcpAuthActivitiesExample.test4" /> <not>
> <test args="e" property="rcpAuthActivitiesExample.test5" /> </not>
> </or>
> </and>
> better.)
TIAS (Try It And See :-) ... but your expression looks fine to me.
multi-line to make it a little more clear:
<and>
<or>
<not>
</not>
</or>
</and>
[/xml]
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Wiki update about complex expressions [message #325629 is a reply to message #325541] Sat, 23 February 2008 13:06 Go to previous message
I just got the impression, like: this should work, but who does this
anyway? And why? An our unit tests for this are only superficial. It's
just that I mistrust any undocumented feature. But you're right: the .xsd
should be enough reliable documentation.
Later,
Jan
Previous Topic:Suggestion for daily build
Next Topic:Jobs and unloading of plugins
Current Time: Thu Nov 20 13:28:06 EST 2025
Powered by FUDForum. Page generated in 0.03792 seconds
