Home » Eclipse Projects » Eclipse Platform » LaunchConfiguration -> Output
LaunchConfiguration -> Output [message #325184] Tue, 12 February 2008 04:31 Go to next message
Originally posted by: b26rsfdi8r6u643.mail.svenz.eu
I'm looking for a possibility to specify the stream/ location where to
write the output of the launched target. I don't want to set the
OutputStream within the LaunchConfigurationDelegate to keep up the
separation of the non-UI & UI code, e.g. when using Console view
(ConsolePlugin).
I wasn't able to determine who the java launcher does that, but I guess it
somehow correlates with the LaunchConfiguration itself!?
Any hints!?
Regards, Tom.
Re: LaunchConfiguration -> Output [message #325404 is a reply to message #325184] Mon, 18 February 2008 03:13 Go to previous messageGo to next message
sorry to push my own thread, but I still haven't found a satisfying
solution and it would be great if there still turn up a hint from you guys
Thanks, Tom.
Re: LaunchConfiguration -> Output [message #325451 is a reply to message #325404] Tue, 19 February 2008 05:29 Go to previous messageGo to next message
AFAIK, the "trick" to show output in the debug console of a launched
object/process is within the IProcess implementation.
IProcess.getStreamsProxy() returns a proxy object which is used to connect
error and output stream to the debug console. Problem is, if you don't
maintain you own process implementation/debug model, I cannot see how to
influence IProcess.getStreamsProxy().
Regards, Uwe
"Tom Oleg" <b26rsfdi8r6u643@mail.svenz.eu> wrote in message
news:fbc463c27fe4e0b807dba2f2bfe38078$1@www.eclipse.org...
> Thanks, Tom.
Re: LaunchConfiguration -> Output [message #325497 is a reply to message #325451] Wed, 20 February 2008 05:15 Go to previous message
Hmmm, first of: thanks for your reply :)
Regarding the StreamsProxy thing: I guess I'm struggling with a more basic
issue. How do I access any of these objects from "outside". I though I
would make sense to fetch a single LaunchConfiguration, specify the output
or probably on that way somehow use the StreamsProxy, but the only entry
point (if any) seem to be the TabGroup or the Tabs itself, which feels
really wrong???
A separate extension point, which can be used within the UI/user plug-in
would be nice *fg* but there isn't something like that, right?
Actually for the moment I just want to start an internal accessible class
and tell the LaunchDelegate on some way to use the ConsolePlugin's
Outputstream.
Regards, Tom.
Previous Topic:Whither 3.3.2?
Next Topic:TableViewer refresh
Current Time: Mon Nov 17 18:51:51 EST 2025
Powered by FUDForum. Page generated in 0.03637 seconds
