| Proxy Settings and plugincustomization, core.net.prefs [message #324943] |
Mon, 04 February 2008 13:00  |
I'm actually packaging a relocatable eclipse/maven/tomcat package (and it
works pretty fine ;)) thanks to the plugincustomization option of the
eclipse runtime. But I'm still having a problem with the proxy settings.
When I export my preferences I can see the proxy options in my preference
file. But when I launch eclipse with the pluginoptimization option ...
nothing in the proxy preferences window.
I've found out that the proxy properties where actually stored in the
workspace metadata in the
plugins/org.eclipse.core.runtime/.settings/org.eclipse.core. net.prefs
file. So I tried, as a guess, to put this file in the configuration folder
of my eclipse folder (hope you follow). I tried in configuration/.settings
and in configuration/org.eclipse.net.prefs/.settings ... No results either.
Is there any way I can set proxy settings in eclipse once and for all ? Is
it possible to edit one the eclipse .jar to store the proxy preferences
for good ? Is it possible to copy by default a proxy pref file when a
workspace is created ?
Thanks in advance for any reply
Manu
FUDForum. Page generated in 0.03528 seconds
