Home » Eclipse Projects » Eclipse Platform » How to inherit window icons to child windows / dialogs [swt/jface]
How to inherit window icons to child windows / dialogs [swt/jface] [message #324841] Fri, 01 February 2008 16:45 Go to next message
Hi Folks,
I have a problem whereby I've set a icon up for my ApplicationWindow as follows
getShell().setImages( new Image[] { image } );
but all child windows / dialogs etc don't inherit the icon, they show the default white box icon (on windows). Does anyone know how to
inherit the icon when using for example the MessageDialog?
Or, can I disable icons completly? for just child windows?
I've tried
setDefaultImage(null);
on the ApplicationWindow.createContents() method but no joy.
Also, when would I need to pass in multiple images to the above image array, and what is that for?
Thanks in advance
Toby
Re: How to inherit window icons to child windows / dialogs [swt/jface] [message #324860 is a reply to message #324841] Sat, 02 February 2008 18:59 Go to previous messageGo to next message
You may want to see the Window.setDefaultImages() method.
If you are using an RCP application, you can set the windowImages
property within the org.eclipse.core.runtime.products extension point.
Snjeza
Toby Weston wrote:
> Hi Folks,
> I've tried
> Thanks in advance
> Cheers,
> Toby
Re: How to inherit window icons to child windows / dialogs [swt/jface] [message #324876 is a reply to message #324860] Sun, 03 February 2008 13:51 Go to previous messageGo to next message
I've been looking at that and by passing a valid image through I get the icon appearing! yey!
I wonder how though I can get no icon appearing? Looking at the source, it seems to not make sence to set it to null as it doesn't do anything with it?
Any ideas?
Cheers
Re: How to inherit window icons to child windows / dialogs [swt/jface] [message #324878 is a reply to message #324876] Sun, 03 February 2008 14:59 Go to previous message
You can create an icon with a transparent background and without contents.
Snjeza
Toby Weston wrote:
> Any ideas?
> Cheers
Previous Topic:Accessibility: need thicker caret
Next Topic:Weird html/xml error markers
Current Time: Fri Sep 19 07:38:54 EDT 2025
Powered by FUDForum. Page generated in 0.04371 seconds
