Home » Eclipse Projects » Eclipse Platform » Platform.getExtensionRegistry() return null
Platform.getExtensionRegistry() return null [message #324727] Thu, 31 January 2008 06:25 Go to next message
Originally posted by: marco.aleroma.virgilio.it
I'm using eclipse to develope a project in witch I use some classes of
eclipse expecially some plugin.
I have an error with the class org.eclipse.core.runtime.Platform.
When I execute the instruction:
IExtensionRegistry registry = Platform.getExtensionRegistry();
registry is null. I think that I must to initialize the registry but I
don't know very well how do it and what is this registry.
Can you help me, please?
Best regards.
Re: Platform.getExtensionRegistry() return null [message #324773 is a reply to message #324727] Thu, 31 January 2008 15:22 Go to previous messageGo to next message
Originally posted by: mark_melvin.amis.com
That seems odd. What type of application are you running your code in? =
Is it a full Eclipse Runtime application or are you trying something =
different like an OSGI or RCP app? You aren't by any chance setting =
eclipse.createRegistry=3Dfalse anywhere on the command line?
Mark.
On Thu, 31 Jan 2008 06:25:18 -0500, jama <marco.aleroma@virgilio.it> wro=
te:
> Hello,
> I'm using eclipse to develope a project in witch I use some classes of=
> I have an error with the class org.eclipse.core.runtime.Platform. When=
I =
> IExtensionRegistry registry =3D Platform.getExtensionRegistry();
> registry is null. I think that I must to initialize the registry but I=
> Best regards.
Re: Platform.getExtensionRegistry() return null [message #324788 is a reply to message #324773] Fri, 01 February 2008 05:35 Go to previous messageGo to next message
Thanks for the answer.
I don't know very well what the registry must to contain and how it must
to be set! I run in an ambient OSGI but I don't have understand if I must
to load anything on the registry.
I've seen that perhaps I must to use the BundleContex, it's true? How can
I create and set this object?
Re: Platform.getExtensionRegistry() return null [message #324814 is a reply to message #324788] Fri, 01 February 2008 10:41 Go to previous messageGo to next message
Sorry - you are beyond me. I have never done an OSGI-only application. I
didn't think you had to do anything special, but you may need to start or
initialize something if you are doing low-level OSGI. You can probably
glean some info from the source for
org.eclipse.core.internal.registry.osgi.Activator, but you may be better
off asking your questions inf the eclipse.technology.equinox newsgroup.
Mark.
> must to load anything on the registry.
> can I create and set this object?
Re: Platform.getExtensionRegistry() return null [message #324921 is a reply to message #324814] Mon, 04 February 2008 10:03 Go to previous message
I have seen that the instruction Platform.getExtensionRegistry() always
return null. But it's impossible because in the installation of eclipse
the registry contain a lot of plug-in.
How is it possible?
Previous Topic:Forcing the refresh of a decoration
Next Topic:Goto Matching Bracket not working for JSP or JS file..?
Current Time: Mon Nov 10 08:05:36 EST 2025
Powered by FUDForum. Page generated in 0.03879 seconds
