Home » Language IDEs » AspectJ » automatic code insertion
automatic code insertion [message #32841] Mon, 12 April 2004 12:14 Go to next message
Hi-
I need help for automatic code insertion using templates if possible or
otherwise.
I have a class that has suppose 8 methods and 2 constructors.
I want that a System.out is inserted just after the method/constructor
declaration..is there an automatic way to do this in Eclipse/AJDT for an
Existing Class?
Eclipse 3.0 M7 is what I have so let me know which AJDT Version is
compatible with this. After Code Insertion..I can compile as usual.
Re: automatic code insertion [message #32874 is a reply to message #32841] Mon, 12 April 2004 17:25 Go to previous message
Originally posted by: newsserver_mails.bodden.de
Hi.
> or otherwise.
I do not understand what that has to do with AJDT? Do you want to use AOP or
do you want to use "standard-OO" code insertion?
> an Existing Class?
I assume you mean System.out.println(String). Sure you can do that - with an
"after" advice.
There is no compatible AJDT build for M7. Version 1.1.4 works with M4 and
the current 1.1.7 dev seems to work with M8 (see earlier postings).
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
GPG: BB465582
Re: automatic code insertion [message #577287 is a reply to message #32841] Mon, 12 April 2004 17:25 Go to previous message
Hi.
> or otherwise.
> an Existing Class?
"after" advice.
Eric
Eric Bodden
ICQ UIN: 12656220
GPG: BB465582
Previous Topic:automatic code insertion
Next Topic:Re. the AJDT user guide
Current Time: Fri Nov 07 08:45:31 EST 2025
Powered by FUDForum. Page generated in 0.03563 seconds
