Home » Eclipse Projects » Eclipse Platform » java.lang.OutOfMemoryError: Java heap space
java.lang.OutOfMemoryError: Java heap space [message #324577] Sun, 27 January 2008 19:00 Go to next message
I'm receiving frequently java.lang.OutOfMemoryError: Java heap space errors.
I did increase the settings in Eclipse.ini to the following values:
-Xms356m
-Xmx640m
-Xmn128m
-XX:+UseParallelGC
-XX:MaxPermSize=256
If I monitor Eclipse in the Windows task manager I see that Eclipse is
around 230 MB before crashing; to my knowledge my settings should be
sufficient.
The system asked me to check .log for additional information but I cannot
find any .log files other then the install.log and error_recovery.log, both
do not contain additional information.
Any advice?
Best regards, Lars
Re: java.lang.OutOfMemoryError: Java heap space [message #324578 is a reply to message #324577] Sun, 27 January 2008 19:15 Go to previous messageGo to next message
--------------090507010404050001080103
Lars,
If your settings were taking effect, you'd get up to 640. Look in the
<workspace>/.metadata/.log for track traces. Is it regular memory or
permgen that's running out? My eclipse.ini looks like this so I'm not
sure your max perm size is quite right.
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
-vmargs
-Xms40m
-Xmx256m
You might have to run with -clean for eclipse.ini changes to take
effect. And note that in 3.3.1 the launcher argument was being ignored
and that was fixed in 3.3.1.1.
Lars Vogel wrote:
> Hello,
> -Xms356m
> -Xmx640m
> -Xmn128m
> -XX:+UseParallelGC
> -XX:MaxPermSize=256
> sufficient.
> Any advice?
> Best regards, Lars
<html>
<head>
</head>
Lars,<br>
<br>
If your settings were taking effect, you'd get up to 640.&nbsp; Look in the
&lt;workspace&gt;/.metadata/.log for track traces.&nbsp; Is it regular
memory or permgen that's running out? My eclipse.ini looks like this so
I'm not sure your max perm size is quite right.&nbsp;
<blockquote>-showsplash<br>
org.eclipse.platform<br>
--launcher.XXMaxPermSize<br>
256m<br>
-vmargs<br>
-Xms40m<br>
-Xmx256m<br>
</blockquote>
effect.&nbsp; And note that in 3.3.1 the launcher argument was being ignored
and that was fixed in 3.3.1.1.<br>
<br>
<br>
Lars Vogel wrote:
<blockquote cite="mid:fnj5uk$gap$1@build.eclipse.org" type="cite">
<pre wrap="">Hello,
-Xms356m
-Xmx640m
-Xmn128m
-XX:+UseParallelGC
-XX:MaxPermSize=256
sufficient.
Any advice?
Best regards, Lars
</pre>
</blockquote>
<br>
</body>
</html>
--------------090507010404050001080103--
Re: java.lang.OutOfMemoryError: Java heap space [message #324579 is a reply to message #324578] Sun, 27 January 2008 19:55 Go to previous messageGo to next message
------=_NextPart_000_005E_01C86150.ED53CFF0
charset="iso-8859-1"
Hi Ed,
thank you for your response. The error which currently occurs is =
java.lang.OutOfMemoryError; I haven't seen a permgen error in days. ;-)=20
I'll try your settings (with increased values) and see if the problem =
persists. I'm running also 3.3.1.1
Thanks again, Lars
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fnj6r7$lqv$1@build.eclipse.org...
Lars,
If your settings were taking effect, you'd get up to 640. Look in the =
<workspace>/.metadata/.log for track traces. Is it regular memory or =
permgen that's running out? My eclipse.ini looks like this so I'm not =
sure your max perm size is quite right. =20
-showsplash
256m
-vmargs
-Xms40m
-Xmx256m
You might have to run with -clean for eclipse.ini changes to take =
effect. And note that in 3.3.1 the launcher argument was being ignored =
Lars Vogel wrote:=20
I'm receiving frequently java.lang.OutOfMemoryError: Java heap space =
errors.
-Xms356m
-Xmx640m
-Xmn128m
-XX:+UseParallelGC
-XX:MaxPermSize=3D256
If I monitor Eclipse in the Windows task manager I see that Eclipse is=20
around 230 MB before crashing; to my knowledge my settings should be=20
sufficient.
The system asked me to check .log for additional information but I =
cannot=20
find any .log files other then the install.log and error_recovery.log, =
both=20
Any advice?
Best regards, Lars=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>thank you for your response. The error =
which=20
currently occurs is java.lang.OutOfMemoryError;&nbsp;I haven't seen a =
permgen=20
error in days. ;-)&nbsp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'll try your settings (with increased =
values) and=20
see if the problem persists. I'm running also 3.3.1.1</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks again, Lars</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:fnj6r7$lqv$1@build.eclipse.org">news:fnj6r7$lqv$1@build.ecli=
pse.org</A>...</DIV>Lars,<BR><BR>If=20
your settings were taking effect, you'd get up to 640.&nbsp; Look in =
the=20
&lt;workspace&gt;/.metadata/.log for track traces.&nbsp; Is it regular =
memory=20
or permgen that's running out? My eclipse.ini looks like this so I'm =
not sure=20
your max perm size is quite right.&nbsp;=20
<BLOCKQUOTE>-showsplash<BR>org.eclipse.platform<BR>--launcher.XXMaxPermSi=
ze<BR>256m<BR>-vmargs<BR>-Xms40m<BR>-Xmx256m<BR></BLOCKQUOTE >You=20
effect.&nbsp;=20
And note that in 3.3.1 the launcher argument was being ignored and =
that was=20
fixed in 3.3.1.1.<BR><BR><BR>Lars Vogel wrote:=20
<BLOCKQUOTE cite=3Dmid:fnj5uk$gap$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hello,
errors.
-Xms356m
-Xmx640m
-Xmn128m
-XX:+UseParallelGC
sufficient.
cannot=20
both=20
Any advice?
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_005E_01C86150.ED53CFF0--
Re: java.lang.OutOfMemoryError: Java heap space [message #324580 is a reply to message #324577] Sun, 27 January 2008 23:51 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:fnj5uk$gap$1@build.eclipse.org...
> Hello,
> errors.
> -Xms356m
> -Xmx640m
> -Xmn128m
> -XX:+UseParallelGC
> -XX:MaxPermSize=256
I take it from those options that you're running on some sort of Unix. Can
you be more specific about your JRE and platform?
Might help to post your config details, and perhaps any interesting snippets
from your .log file.
How big are your workspaces and what kind of projects are you working on?
Is it, in fact, possible that you just need even more memory? (E.g., do you
still run out if you set -Xmx1024m?) I agree that's not consistent with the
heap indicator showing only 230MB but maybe there's something funny going
on.
Re: java.lang.OutOfMemoryError: Java heap space [message #324648 is a reply to message #324580] Tue, 29 January 2008 18:56 Go to previous messageGo to next message
Hi Walter,
thank you for your reply.
I actually do use Windows XP with JRE 1.6.
I did increase my memory as suggest by you and will report if I get another
crash. The workspace I'm working in is about 80 MB, it mainly consists of
XML files and several plug-in projects.
Snippet of the log file attached (see below).
Best regards, Lars
!STACK 0
java.lang.ClassCastException: java.lang.OutOfMemoryError cannot be cast to
org.eclipse.core.runtime.CoreException
org.eclipse.jdt.internal.debug.ui.launcher.JavaApplicationLa unchShortcut.findTypes(JavaApplicationLaunchShortcut.java:11 2)
org.eclipse.jdt.internal.debug.ui.launcher.JavaLaunchShortcu t.searchAndLaunch(JavaLaunchShortcut.java:56)
org.eclipse.jdt.internal.debug.ui.launcher.JavaLaunchShortcu t.launch(JavaLaunchShortcut.java:227)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchSho rtcutExtension.launch(LaunchShortcutExtension.java:429)
org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.r un(LaunchShortcutAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
"Walter Harley" <wharley@bea.com> wrote in message
news:fnjn00$ou1$1@build.eclipse.org...
>> Hello,
>> errors.
>> -Xms356m
>> -Xmx640m
>> -Xmn128m
>> -XX:+UseParallelGC
>> -XX:MaxPermSize=256
> Can you be more specific about your JRE and platform?
> snippets from your .log file.
> you still run out if you set -Xmx1024m?) I agree that's not consistent
> with the heap indicator showing only 230MB but maybe there's something
> funny going on.
Re: java.lang.OutOfMemoryError: Java heap space [message #324650 is a reply to message #324648] Tue, 29 January 2008 19:59 Go to previous messageGo to next message
news:fnoeev$fkg$1@build.eclipse.org...
> Hi Walter,
You said your parameters were:
> -Xms356m
> -Xmx640m
> -Xmn128m
> -XX:+UseParallelGC
> -XX:MaxPermSize=256
I'm concerned about that "256", which seems like it should have an 'm' after
it. I know you're not getting permgen failures, I'm just digging for
anything unusual about your configuration.
Do you still get the failures if you simplify these options, e.g., get rid
of the ParallelGC and the -Xmn? I'm not sure those are doing you any good
in a client app. In particular, the -Xmn is going to be reducing the
effective size of your heap.
Also, do you get anything useful if you add
"-XX:+HeapDumpOnOutOfMemoryError"? (Not that digging through 1G of dumped
heap is a pleasure.)
Re: java.lang.OutOfMemoryError: Java heap space [message #324683 is a reply to message #324648] Wed, 30 January 2008 12:11 Go to previous messageGo to next message
Lars Vogel wrote:
> Hi Walter,
> Best regards, Lars
> !STACK 0
> at
Hmm, that is a strange error. It is not directly reporting an
OutOfMemoryError, but rather that something in the JDT launching code is
trying to cast an OOM to a CoreException. That suggests to me two
possible things:
1) that Eclipse itself may not be actually running out of memory, but
the app you're trying to run does
2) that there is a bug in the JDT launching code where it is trying to
do the cast that is invalid.
Lars, can you repeat the description of the behavior you see when this
happens? Does Eclipse continue to function or become
unusable/nonres-ponsive? Or does it hard-crash altogether? Etc...
Eric
Re: java.lang.OutOfMemoryError: Java heap space [message #324689 is a reply to message #324650] Wed, 30 January 2008 13:16 Go to previous messageGo to next message
Hi Walter,
with the increased parameters from Ed I did not yet receive a dump.
So currently me eclipse.ini looks like the following:
-showsplash
512m
-vmargs
-Xms40m
-Xmx512m
If I receive this error again I will make the HeapDump available if that is
useful.
Best regards, Lars
news:fnoi6b$gpn$1@build.eclipse.org...
>> Hi Walter,
>> -Xms356m
>> -Xmx640m
>> -Xmn128m
>> -XX:+UseParallelGC
>> -XX:MaxPermSize=256
> after it. I know you're not getting permgen failures, I'm just digging
> for anything unusual about your configuration.
Re: java.lang.OutOfMemoryError: Java heap space [message #324690 is a reply to message #324683] Wed, 30 January 2008 13:18 Go to previous message
Hi Eric,
usally Eclipse becomes unusable after this error. In some cases I can close
it in some I have to kill it via the task list.
If it happens again (I changed the settings) I try to report more.
Best regards, Lars
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:fnqb25$q8a$1@build.eclipse.org...
> Lars Vogel wrote:
>> Hi Walter,
>> another crash. The workspace I'm working in is about 80 MB, it mainly
>> consists of XML files and several plug-in projects.
>> Best regards, Lars
>> !STACK 0
>> to org.eclipse.core.runtime.CoreException
>> at
> trying to cast an OOM to a CoreException. That suggests to me two possible
> things:
> 1) that Eclipse itself may not be actually running out of memory, but the
> 2) that there is a bug in the JDT launching code where it is trying to do
> Eric
Previous Topic:Creating PropertySource from Map (value pair) objects.
Next Topic:Enhancing the JDT Java Editor
Current Time: Sat Nov 22 09:32:02 EST 2025
Powered by FUDForum. Page generated in 0.04410 seconds
