| getImageDescriptorFromProgram, what format filename input parameter expects ? [message #324501] |
Fri, 25 January 2008 05:27  |
There is a method in the WorkbenchImages class called
getImageDescriptorFromProgram(String filename, int offset). The
documentation says that "This consults the plugin for extension and
obtains its installation location. All requested images are assumed to be
in a directory below and relative to that plugin's installation
directory.". Can somebody please let me know what is the expected value
for the filename parameter here. Is it just a filename, a complete URL or
a relative URL in the bundle context.
Warm Regards,
Rajesh
| Re: getImageDescriptorFromProgram, what format filename input parameter expects ? [message #324508 is a reply to message #324506] |
Fri, 25 January 2008 07:09  |
Rajesh,
Run Eclipse under debug control and set a breakpoint in the interesting
methods. See how things get there. It seems to me, looking at the
code, that it could only be used to retrieve things that have been
cached by some other part of the system. So perhaps your predecessor
was using it as a sneaky (no-API) way to gain access to some images.
When I set a breakpoint there, I don't even see it get called...
Does your software ever actually call this method today. If so, use the
debugger to trace into the behavior of the method that way...
Rajesh Adukkadukkath wrote:
> Ed,
> Actually a developer who was a my predessor for my application used
> this method for some purpose which I am trying to findout now. My
> objective is to modify the implementation this method in my code that
> uses the "ProgramImageDescriptor" with a alternative. I will not be
> able to modify the method, method signature because it will break the
> customization done over my application by customers when they migrate
> the code. \
> So my plan is to:
> 1) Understand what WoekbenchMessages.getImageDescriptorFromProgram()
> is doing internally in eclipse, besed on what implementation did my
> collegue was trying to provide.
> 2) Provide an alternative implementation without any API Changes, also
> wihout using any internal classes.
> Any help would be really appreciated.
> Warm Regards,
> Rajesh
FUDForum. Page generated in 0.03948 seconds
