Home » Eclipse Projects » Eclipse Platform » Constructor of class extending AbstractUIPlugin is not called
Constructor of class extending AbstractUIPlugin is not called [message #324491] Thu, 24 January 2008 21:24 Go to next message
Originally posted by: weber.lars.googlemail.com
Hi!
I'm about to write a plugin and I am stuck with nullpointer, I don't
understand. Google Codesearch and Krugle did not get me any further.
My class extends org.eclipse.ui.plugin.AbstractUIPlugin.
Everything works fine, but when I execute my plugin, then I get a
nullpointer exeption in my getStore() method.
I once called the constructor by myself, but then the getPreferenceStore
returns null.
As far as I have understood, the DClarePlugin Class is initialized by
Eclipse (Europa) and I don't have to do this? What did I misunderstand.
Where is the right place to initialize this class.
Lars
public class DClarePlugin extends AbstractUIPlugin {
private static DClarePlugin plugin;
public DClarePlugin() {
super();
plugin = this;
public static DClarePlugin getDefault() {
return plugin;
public static IPreferenceStore getStore() {
//getDefault returns NULL!
return getDefault().getPreferenceStore();
Re: Constructor of class extending AbstractUIPlugin is not called [message #324493 is a reply to message #324491] Fri, 25 January 2008 02:29 Go to previous messageGo to next message
--------------010503010105080701020107
Lars,
Does your MANIFEST.MF contains a line like this?
Bundle-Activator: org.example.DClarePlugin
Lars Weber wrote:
> Hi!
> getPreferenceStore returns null.
> misunderstand. Where is the right place to initialize this class.
> Lars
> super();
> plugin = this;
> return plugin;
<html>
<head>
http-equiv="Content-Type">
</head>
Lars,<br>
<br>
Does your MANIFEST.MF contains a line like this?<br>
<blockquote>Bundle-Activator: org.example.DClarePlugin <br>
</blockquote>
<br>
<br>
Lars Weber wrote:
<blockquote
cite="mid:24d1c319297301dd98a0b2d5d9d6cbb9$1@www.eclipse.org"
type="cite">Hi!
<br>
<br>
<br>
<br>
<br>
<br>
<br>
getPreferenceStore returns null. <br>
<br>
<br>
<br>
<br>
Lars
<br>
<br>
<br>
<br>
[solved] Re: Constructor of class extending AbstractUIPlugin is not called [message #324503 is a reply to message #324493] Fri, 25 January 2008 05:37 Go to previous message
Thanks Ed!
That was the solution!
Greetings from Germany,
Lars
> Lars Weber wrote:
>> Hi!
>> Thanks,
>> Lars
>> super();
>> plugin = this;
>> return plugin;
Previous Topic:splashHandler
Next Topic:getImageDescriptorFromProgram, what format filename input parameter expects ?
Current Time: Sat Nov 22 02:17:16 EST 2025
Powered by FUDForum. Page generated in 0.23967 seconds
