Home » Eclipse Projects » Eclipse Platform » Creating custom .project / .classpath file?
Creating custom .project / .classpath file? [message #324237] Mon, 21 January 2008 07:21 Go to next message
Originally posted by: pnakat.gmail.com
I am creating a custom defined project type ABC which has its own nature
ABCNature. I want to save a few files/paths related to the new project
(like source folder, output folder in case of a Java Project) in a special
project / .classpath file say .abcProject file. This file should contain
it's own classPathEntries (CPE's like java .classpath) file.
For example, the .abcProject file would contain an entry for repository as
<repository>
<path> C:\abc\xyz\qwert.xml</path>
<active>yes</active>
</repository>
OR
type = "repository" path = "C:\abc\xyz\qwert.xml"
in .classpath file.
Can someone please guide me if this is possible in Eclipse? If yes, how do
i proceed with creating a special .project file and define tags in it?
Prajakta
Re: Creating custom .project / .classpath file? [message #324242 is a reply to message #324237] Mon, 21 January 2008 08:34 Go to previous message
--------------080405090405080309030601
Prajakta,
Here's a big whack of code where the use of JET_NATURE_PROPERTIES_FILE
might help understand how we do something similar:
* <copyright>
* Copyright (c) 2002-2006 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM - Initial API and implementation
* </copyright>
* $Id: JETNature.java,v 1.8 2007/06/12 20:56:05 emerks Exp $
package org.eclipse.emf.codegen.jet;
import java.io.BufferedInputStream;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.StringReader;
import java.io.StringWriter;
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
import java.util.StringTokenizer;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.ParserConfigurationException;
import javax.xml.transform.OutputKeys;
import javax.xml.transform.Transformer;
import javax.xml.transform.TransformerException;
import javax.xml.transform.TransformerFactory;
import javax.xml.transform.dom.DOMSource;
import javax.xml.transform.stream.StreamResult;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
import org.w3c.dom.Node;
import org.w3c.dom.Text;
import org.xml.sax.InputSource;
import org.xml.sax.SAXException;
import org.eclipse.core.resources.ICommand;
import org.eclipse.core.resources.IContainer;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IFolder;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IProjectDescription;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.emf.codegen.CodeGenPlugin;
import org.eclipse.emf.common.util.URI;
public class JETNature implements IJETNature
* Get a JETNature that corresponds to the supplied project.
* @return JETNature
* @param project IProject
public static JETNature getRuntime(IProject project)
try
JETNature a = (JETNature) project.getNature(IJETNature.NATURE_ID);
return a;
catch (CoreException e)
return null;
protected static final String BUILDER = "JETBuilder";
protected static final String DEFAULT_TEMPLATE_CONTAINER_NAME =
"templates";
protected static final String JET_NATURE_PROPERTIES_FILE =
".jetproperties";
protected static final String TEMPLATE_CONTAINER_NODE =
"template-container";
protected static final String SOURCE_CONTAINER_NODE =
"source-container";
protected static final String JET_SETTINGS_NODE = "jet-settings";
protected IProject jetProject;
protected List<Object> jetTemplateContainers;
protected List<Object> jetTemplateSourceContainers;
protected IContainer jetJavaSourceContainer;
* Constructor for JETNature.
public JETNature()
super();
public List<Object> getTemplateContainers()
if (jetTemplateContainers == null)
jetTemplateContainers = getTemplateContainersFromFile();
return jetTemplateContainers;
public List<Object> getTemplateSourceContainers()
if (jetTemplateSourceContainers == null)
getTemplateSourceContainersFromFile();
return jetTemplateSourceContainers;
public IContainer getJavaSourceContainer()
if (jetJavaSourceContainer == null)
jetJavaSourceContainer = getJavaSourceContainerFromFile();
return jetJavaSourceContainer;
public void setTemplateContainers(List<Object> templateContainers)
setTemplateContainers(templateContainers, templateContainers);
public void setTemplateContainers(List<Object> templateContainers,
List<Object> templateSourceContainers)
jetTemplateContainers = templateContainers;
jetTemplateSourceContainers = templateSourceContainers;
try
setTemplateContainersToFile(templateContainers,
templateSourceContainers);
CodeGenPlugin.write(e);
public void setJavaSourceContainer(IContainer javaSourceContainer)
jetJavaSourceContainer = javaSourceContainer;
try
setJavaSourceContainerToFile(javaSourceContainer);
public void configure() throws CoreException
configure(new NullProgressMonitor());
public void configure(IProgressMonitor monitor) throws CoreException
setDefaults(monitor);
// Add JETBuilder
addToFrontOfBuildSpec(CodeGenPlugin.INSTANCE.getSymbolicName () +
"." + BUILDER);
* Sets the containers to their defaults.
public void setDefaults(IProgressMonitor monitor) throws CoreException
initTemplateContainer(monitor);
initJavaSourceContainer(monitor);
// Create .jetproperties file
try
createDefaultJETSettingsFile(getTemplateContainers(),
getJavaSourceContainer());
catch (IOException e)
public void deconfigure() throws CoreException
// Do nothing
public IProject getProject()
return jetProject;
public void setProject(IProject project)
jetProject = project;
* Initializes the template container.
protected void initTemplateContainer(IProgressMonitor monitor)
IContainer templateFolder = getContainer(getProject(),
DEFAULT_TEMPLATE_CONTAINER_NAME);
if (templateFolder instanceof IFolder && !templateFolder.exists())
((IFolder) templateFolder).create(true, true, monitor);
jetTemplateContainers = new ArrayList<Object>();
jetTemplateContainers.add(templateFolder);
jetTemplateSourceContainers = new ArrayList<Object>();
jetTemplateSourceContainers.add(templateFolder);
* Initializes the Java Source Container
protected void initJavaSourceContainer(IProgressMonitor monitor)
IContainer sourceFolder = getContainer(getProject(),
getDefaultSourcePath());
if (sourceFolder instanceof IFolder && !sourceFolder.exists())
((IFolder)sourceFolder).create(true, true, monitor);
jetJavaSourceContainer = sourceFolder;
* Returns the project's root directory
protected IPath getDefaultSourcePath()
IPath path = new Path("");
return path;
* Adds a builder to the build specification for the given project.
protected void addToFrontOfBuildSpec(String builderID) throws
CoreException
IProjectDescription description = getProject().getDescription();
ICommand[] commands = description.getBuildSpec();
boolean found = false;
for (int i = 0; i < commands.length; ++i)
if (commands[i].getBuilderName().equals(builderID))
found = true;
break;
if (!found)
ICommand command = description.newCommand();
command.setBuilderName(builderID);
ICommand [] newCommands = new ICommand [commands.length + 1];
System.arraycopy(commands, 0, newCommands, 1, commands.length);
newCommands[0] = command;
description.setBuildSpec(newCommands);
getProject().setDescription(description, null);
* Returns the template path from the .jetproperties file.
public List<Object> getTemplateContainersFromFile()
List<Object> result = Collections.emptyList();
try
Document document = parseJETSettings();
if (document != null)
result = getContainerValues(document.getDocumentElement(),
TEMPLATE_CONTAINER_NODE, false);
else
setDefaults(new NullProgressMonitor());
result = getTemplateContainers();
catch (Exception e)
try
catch (Exception ex)
CodeGenPlugin.write(ex);
return result;
* Returns the template source path from the .jetproperties file.
protected List<Object> getTemplateSourceContainersFromFile()
try
TEMPLATE_CONTAINER_NODE, true);
else
catch (Exception e)
try
return result;
* Returns the template file from the .jetproperties file
public IContainer getJavaSourceContainerFromFile()
IContainer result = null;
try
result = getContainerValue(document.getDocumentElement(),
SOURCE_CONTAINER_NODE);
else
result = getJavaSourceContainer();
catch (Exception e)
try
return result;
* Parse the JET settings file for the root element.
protected Document parseJETSettings() throws
ParserConfigurationException, SAXException, IOException, CoreException
Document document = null;
StringReader reader = readJETSettingFile();
if (reader != null)
DocumentBuilderFactory documentBuilderFactory =
DocumentBuilderFactory.newInstance();
documentBuilderFactory.setNamespaceAware(true);
documentBuilderFactory.setValidating(false);
DocumentBuilder parser =
documentBuilderFactory.newDocumentBuilder();
document = parser.parse(new InputSource(reader));
if
(!document.getDocumentElement().getNodeName().equalsIgnoreCa se(JET_SETTINGS_NODE))
CodeGenPlugin.write(new
IOException(CodeGenPlugin.getPlugin().getString("_UI_MalformedJETPropertiesFile_exception ")));
reader.close();
return document;
* Open the JET Settings file and return a StringReader on the
contents
protected StringReader readJETSettingFile() throws CoreException,
IOException
StringReader reader = null;
IFile jetSettingsFile =
getProject().getFile(JET_NATURE_PROPERTIES_FILE);
if (jetSettingsFile.exists())
InputStream input = jetSettingsFile.getContents(true);
String jetSettings = new String(readContentsAsBytes(input));
reader = new StringReader(jetSettings);
return reader;
* Returns the containers defined from the base Element passed in.
protected List<Object> getContainerValues(Element element, String
localName)
return getContainerValues(element, localName, false);
with entries starting with @ filtered out.
localName, boolean filter)
List<Object> result = new ArrayList<Object>();
Element childElement = getChildWithLocalName(element, localName);
for (Node node = childElement.getFirstChild(); node != null;
node = node.getNextSibling())
if (node.getNodeType() == Node.TEXT_NODE)
result = getContainers(getProject(), node.getNodeValue(),
filter);
break;
if (result.isEmpty())
result.add(getProject());
return result;
* Returns the container defined from the base Element passed in.
protected IContainer getContainerValue(Element element, String
localName)
result = getContainer(getProject(), node.getNodeValue());
break;
if (result == null)
result = getProject();
return result;
protected void setContainerValues(List<Object> containers, Element
element, String localName)
setContainerValues(containers, containers, element, localName);
* Sets the template container locations in the settings file
List<Object> sourceContainers, Element element, String localName)
Text text = null;
text = (Text)node;
break;
if (text == null)
text =
element.getOwnerDocument().createTextNode(getContainers(jetP roject,
containers, sourceContainers));
childElement.appendChild(text);
else
text.setNodeValue(getContainers(jetProject, containers,
sourceContainers));
* Sets the template container location in the settings file
protected void setContainerValue(IContainer container, Element
Text text = null;
text = (Text)node;
break;
if (text == null)
text =
element.getOwnerDocument().createTextNode(container.getProje ctRelativePath().toString());
else
text.setNodeValue(container.getProjectRelativePath().toStrin g());
* Returns the child with the given local name.
protected Element getChildWithLocalName(Element element, String
localName)
for (Node child = element.getFirstChild(); child != null; child
= child.getNextSibling())
if (child.getNodeType() == Node.ELEMENT_NODE)
Element childElement = (Element)child;
if (childElement.getLocalName().equals(localName))
return childElement;
return null;
* Reads an input stream and converts it to bytes
public static byte[] readContentsAsBytes(InputStream input) throws
IOException
BufferedInputStream bufferedInputStream = null;
try
final int BUF_SIZE = 8192;
byte[] buf = new byte[BUF_SIZE];
int read;
int totalRead = 0;
bufferedInputStream = new BufferedInputStream(input);
while (totalRead < BUF_SIZE && (read =
bufferedInputStream.read(buf, totalRead, BUF_SIZE - totalRead)) != -1)
totalRead += read;
if (totalRead < BUF_SIZE)
byte[] result = new byte[totalRead];
System.arraycopy(buf, 0, result, 0, totalRead);
return result;
ByteArrayOutputStream out = new ByteArrayOutputStream(BUF_SIZE
* 2);
out.write(buf);
while ((read = bufferedInputStream.read(buf, 0, BUF_SIZE)) != -1)
out.write(buf, 0, read);
return out.toByteArray();
finally
try
if (bufferedInputStream != null)
bufferedInputStream.close();
public void setTemplateContainersToFile(List<Object>
templateContainers) throws CoreException
setTemplateContainersToFile(templateContainers, templateContainers);
* Writes the Template Container Location to a file
templateContainers, List<Object> templateSourceContainers) throws
CoreException
Document document;
try
try
setContainerValues(templateContainers,
templateSourceContainers, document.getDocumentElement(),
TEMPLATE_CONTAINER_NODE);
commitXML(document);
else
initJavaSourceContainer(new NullProgressMonitor());
createDefaultJETSettingsFile(templateContainers,
catch (Exception e)
templateSourceContainers, getJavaSourceContainer());
catch (Exception e)
* Writes the Java Source Container Location to a file
public void setJavaSourceContainerToFile(IContainer
sourceContainer) throws CoreException
Document document;
try
try
setContainerValue(sourceContainer,
document.getDocumentElement(), SOURCE_CONTAINER_NODE);
else
initTemplateContainer(new NullProgressMonitor());
sourceContainer);
catch (Exception e)
sourceContainer);
catch (Exception e)
protected void createDefaultJETSettingsFile(List<Object>
templateContainers, IContainer sourceContainer)
throws CoreException, IOException
templateContainers, sourceContainer);
* Writes the default file
templateContainers, List<Object> templateSourceContainers,
StringWriter writer = new StringWriter();
// Create a default .jetsettings file file
writer.write("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");
writer.write("\n");
writer.write("<" + JET_SETTINGS_NODE + ">");
writer.write("\n");
writer.write(
"\t<"
+ TEMPLATE_CONTAINER_NODE
+ getContainers(jetProject, templateContainers,
writer.write(
"\t<"
+ SOURCE_CONTAINER_NODE
+ sourceContainer.getProjectRelativePath().toString()
writer.write("\n");
writer.write("</" + JET_SETTINGS_NODE + ">");
writer.write("\n");
InputStream sourceStream = new
ByteArrayInputStream(writer.toString().getBytes());
jetSettingsFile.setContents(sourceStream, true, true, null);
else
jetSettingsFile.create(sourceStream, true, null);
sourceStream.close();
protected void commitXML(Document document) throws CoreException,
ClassNotFoundException, IOException
TransformerFactory transformerFactory =
TransformerFactory.newInstance();
try
Transformer transformer = transformerFactory.newTransformer();
transformer.setOutputProperty(OutputKeys.INDENT, "yes");
transformer.setOutputProperty(OutputKeys.METHOD, "xml");
transformer.transform(new DOMSource(document), new
StreamResult(writer));
catch (TransformerException exception)
CodeGenPlugin.write(exception);
else
public static IContainer getContainer(IProject project, IPath path)
IContainer result = project;
if (!path.isEmpty())
if (path.getDevice() != null)
result = null;
else if (path.isAbsolute() && path.getDevice() == null)
IResource resource =
project.getWorkspace().getRoot().findMember(path);
if (resource instanceof IContainer)
result = (IContainer)resource;
else
result = project.getFolder(path);
return result;
public static IContainer getContainer(IProject project, String path)
return getContainer(project, new Path(path));
public static List<Object> getContainers(IProject project, String
paths)
return getContainers(project, paths, false);
paths, boolean filter)
for (StringTokenizer stringTokenizer = new
StringTokenizer(paths, " ;"); stringTokenizer.hasMoreTokens(); )
String path = stringTokenizer.nextToken();
if (path.startsWith("@"))
if (filter) continue;
path = path.substring(1);
IContainer container = getContainer(project, new Path(path));
if (container == null)
URI uri = URI.createURI(path);
if (!uri.isRelative())
result.add(uri);
else
result.add(container);
return result;
public static String getContainers(IProject project, List<Object>
containers)
return getContainers(project, containers, containers);
containers, List<Object> sourceContainers)
StringBuffer result = new StringBuffer();
for (Object container : containers)
if (result.length() != 0)
result.append(";");
if (!sourceContainers.contains(container))
result.append("@");
if (container instanceof IContainer)
result.append(getContainer(project, (IContainer)container));
else if (container instanceof URI)
result.append(container);
return result.toString();
public static String getContainer(IProject project, IContainer
container)
return
(project == container.getProject() ?
container.getProjectRelativePath() :
container.getFullPath()).toString();
Prajakta wrote:
> nature ABCNature. I want to save a few files/paths related to the new
> project (like source folder, output folder in case of a Java Project)
> in a special project / .classpath file say .abcProject file. This file
> should contain it's own classPathEntries (CPE's like java .classpath)
> file.
> repository as :
> <repository>
> </repository>
> OR
> in .classpath file.
> how do i proceed with creating a special .project file and define tags
> in it?
> Prajakta
<html>
<head>
http-equiv="Content-Type">
</head>
Prajakta,<br>
<br>
Here's a big whack of code where the use of <small>JET_NATURE_PROPERTIES_FILE
</small>might help understand how we do something similar:<br>
<small><br>
</small>
<blockquote><small>/**</small><br>
<small>
Previous Topic:Can you recommend some materials for adapting mechanism of Eclipse.
Next Topic:Disabling dirty asterisk for the project explorer view
Current Time: Wed Sep 17 22:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.02681 seconds
