Home » Eclipse Projects » Eclipse Platform » Programmatically add a file to a project
Programmatically add a file to a project [message #323788] Tue, 08 January 2008 12:12 Go to next message
Originally posted by: jeff_r2.verifone.com
I would like to add a file to an existing project (programmatically).
Either would be acceptable:
1. Add the file when an existing project is imported (that is, somehow
plug into the 'General>Existing Projects into Workspace' from the
'File>Import...' menu selection).
2. At some point check a Workspace project for the existence of a
particular file and add it if it doesn’t exist (triggered by some event
such as starting a build, etc.)
Any guidance would be appreciated.
Thanks.
Jeff
Re: Programmatically add a file to a project [message #323789 is a reply to message #323788] Tue, 08 January 2008 13:00 Go to previous messageGo to next message
Use the resource notification stuff (IResourceChangedEvent,
IResourceDelta, etc) to get notification of when the project is added.
Then you can just create your file using the IResource API.
All of this is described pretty well in the Resources Overview section
of the Platform Development Programmer's Guider in the help.
> particular file and add it if it doesn�t exist (triggered by some event
> Thanks.
> Jeff
Re: Programmatically add a file to a project [message #323825 is a reply to message #323789] Wed, 09 January 2008 10:55 Go to previous message
Thanks, this looks like what I need. Just having trouble bolting it in,
but I'll figure it out eventually.
Previous Topic:How to access menuContribution from WorkbenchWindow - UPDATED
Next Topic:MultipageEditorPart
Current Time: Sat Nov 08 23:20:41 EST 2025
Powered by FUDForum. Page generated in 0.02721 seconds
