| Eclipse command line worspace refresh [message #323346] |
Tue, 18 December 2007 11:51  |
Originally posted by: arturslicis.inbox.lv
I'm exporting my plugins running antRunner from headless Eclipse. Since
source is updated from non-Eclipse environment, the workspace becomes
out-of-date and build procedure might report unexisting errors.
What I tried was '-refresh' argument (seen in docs that such exists), but
Eclipse reports that it's an invalid argument; what I do:
eclipsec.exe -nosplash -refresh -application
org.eclipse.ant.core.antRunner -data .\.. -buildfile build.xml
Unknown argument: -refresh
Buildfile: build.xml
plugin_export:
Tried eclipse.exe with -consolelog as well to see what happens when
ordinary eclipse launched, but result is the same.
Otherwise it works fine, but refresh functionality is really needed.
Any ideas how could I refresh workspace on headless Eclipse startup?
Thank you in advance,
Arturs
| Re: Eclipse command line worspace refresh [message #323352 is a reply to message #323346] |
Tue, 18 December 2007 12:19  |
If you need a workspace refresh, there is an ant task
<eclipse.refreshLocal resource="${resourcePath}" depth="infinite"/>
that you could use.
-Andrew
Arturs Licis wrote:
> Hello,
> but Eclipse reports that it's an invalid argument; what I do:
> plugin_export:
> Arturs
FUDForum. Page generated in 0.02970 seconds
