Home » Eclipse Projects » Eclipse Platform » Try to get the separator with the same style on Eclipse IDE
Try to get the separator with the same style on Eclipse IDE [message #323042] Wed, 05 December 2007 15:20
Originally posted by: rickk.yahoo.com
I am trying to create a separator similar to the leftmost one or the
rightmost one that separate progress indicator and line/char counts on
Eclipse's statusline or similar to the ones that separate Eclipse
toolbars. This separator is wider but a little bit shorter than the one I
mentioned below.
The style bits I use in the following only create a thin/caved-in line:
new Label( composite, SWT.SEPARATOR | SWT.VERTICAL );
What style bits should I use to achieve the same effect?
regards,
Previous Topic:migrate plugin from 3.0 to 3.3
Next Topic:Eclipse Europa hangs often
Current Time: Thu Jul 17 19:17:30 EDT 2025
Powered by FUDForum. Page generated in 0.05611 seconds
