Home » Eclipse Projects » Eclipse Platform » How to replace the BundleClassLoader
How to replace the BundleClassLoader [message #322657] Fri, 23 November 2007 06:03 Go to next message
i would like to replace/overwrite the bundle's classloader. where/how
can i do that?
cheers,
simon
Re: How to replace the BundleClassLoader [message #322663 is a reply to message #322657] Fri, 23 November 2007 07:16 Go to previous message
> can i do that?
All I can say is
1) good luck with that! :-)
2) you might want to check out
http://wiki.eclipse.org/Equinox_Transforms and
http://wiki.eclipse.org/Adaptor_Hooks
and 3) after you've looked at the classloading adapter I would ask in
eclipse.technology.equinox (they implement the classloading strategy
that Eclipse uses).
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Generating extension point XML
Next Topic:which extension point to add library to eclipse?
Current Time: Thu Jul 17 21:31:19 EDT 2025
Powered by FUDForum. Page generated in 0.07967 seconds
