Home » Eclipse Projects » Eclipse Platform » [DataBinding] Observable TreeViewer
[DataBinding] Observable TreeViewer [message #322471] Mon, 19 November 2007 12:30 Go to next message
Hi there,
Pardon the quasi-cross-posting with eclipse.platform.rcp, but I read in
http://wiki.eclipse.org/JFace_Data_Binding/FAQ that I might get a better
response here ...
Databinding with a TableViewer is elegant, à la:
ObservableListContentProvider viewerContentProviderList = new
ObservableListContentProvider();
viewer.setContentProvider(viewerContentProviderList);
IObservableMap[] viewerLabelProviderMaps =
BeansObservables.observeMaps(viewerContentProviderList.getKn ownElements(),
TaxonName.class, new String[]{"name"});
viewer.setLabelProvider(new
ObservableMapLabelProvider(viewerLabelProviderMaps));
IObservableList olObjectListObserveList =
BeansObservables.observeList(Realm.getDefault(),
Activator.getDefault().getTaxonList(), "objectList");
viewer.setInput(olObjectListObserveList);
However, I need to do something similar with a TreeViewer, and am at a
loss as to where or whether I can find something akin to
ObservableListContentProvider for TreeViewer content.
Any help greatly appreciated!
Pepe
Re: [DataBinding] Observable TreeViewer [message #322477 is a reply to message #322471] Mon, 19 November 2007 13:44 Go to previous messageGo to next message
ObservableSetTreeContentProvider is in CVS somewhere, if you check out
the databinding sources you should find it.
I've written my own ObservableListTreeContentProvider, which I'm
contributing to JDB, however it is not well-tested at the moment. The
patch is in bugzilla 207858:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207858
A known problem is that if equivalent nodes are present at multiple
points in the tree and one of them is removed, the content provider
loses track of the other equivalent nodes. Not a big deal if you're
just using the tree in view-only mode though.
Matthew
Re: [DataBinding] Observable TreeViewer [message #322616 is a reply to message #322477] Wed, 21 November 2007 11:49 Go to previous messageGo to next message
Thanks, Matthew!
I wasn't able to find ObservableSetTreeContentProvider in CVS in the
logical places, i.e. org.eclipse.core.databinding and
org.eclipse.jface.databinding, or org.eclipse.core.databinding.beans, for
that matter. Any idea where you might have seen it?
At any rate, I'll see what I can do with your
ObservableListTreeContentProvider tomorrow ...
Re: [DataBinding] Observable TreeViewer [message #322617 is a reply to message #322616] Wed, 21 November 2007 12:00 Go to previous messageGo to next message
It's not in CVS search bugzilla.
Tom
Pepe Ciardelli schrieb:
> Thanks, Matthew!
> for that matter. Any idea where you might have seen it?
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [DataBinding] Observable TreeViewer [message #322671 is a reply to message #322617] Fri, 23 November 2007 11:43 Go to previous message
Originally posted by: bokowski.ca.ibm.com
Actually, it is in org.eclipse.jface.databinding, just under a different
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fi1o6m$5ot$1@build.eclipse.org...
> Tom
>> Thanks, Matthew!
Previous Topic:which extension point to add library to eclipse?
Next Topic:Building update site with platform-specific fragments
Current Time: Sat Nov 22 05:03:16 EST 2025
Powered by FUDForum. Page generated in 0.03739 seconds
