Home » Eclipse Projects » Eclipse Platform » Dynamically refresh a plugin
Dynamically refresh a plugin [message #321572] Sat, 20 October 2007 14:10 Go to next message
I have a plugin which gets installed with a missing dependent library.
When the Activator class of the plugin gets called, the dependent
library gets downloaded, but the plugin cannot recognize or link to the
downloaded library, until eclipse is restarted.
Is there a way, that the plugin can link to the downloaded library,
after the Activator class is called without restarting eclipse. The
download call is made in the start() function of the Activator class.
Samrat Dhillon
Re: Dynamically refresh a plugin [message #321593 is a reply to message #321572] Mon, 22 October 2007 08:22 Go to previous messageGo to next message
Is your dependent library a jar file? If so you can ask OSGi to refresh
the packages that you "export". Check out
org.eclipse.ui.tests.dynamicplugins.TestInstallUtil in
org.eclipse.ui.tests to see how to request an OSGi package refresh. You
must have it in your bundle classpath header in such a way that it can
be found, though.
If it's a native lib, then just having it on the java.library.path
should be enough, no?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Dynamically refresh a plugin [message #321622 is a reply to message #321593] Tue, 23 October 2007 01:45 Go to previous message
> be found, though.
> PW
Thanks for the help.
It worked.
Samrat Dhillon
Previous Topic:[Databinding] Tracking different selections in MasterDetail binding
Next Topic:How to decorate a ViewerColumn ?
Current Time: Sun Nov 16 00:09:10 EST 2025
Powered by FUDForum. Page generated in 0.03659 seconds
