Home » Eclipse Projects » Eclipse Platform » PDE Build: unpacked signed plugins get corrupted when jar-ing for updatesite
PDE Build: unpacked signed plugins get corrupted when jar-ing for updatesite [message #321534] Fri, 19 October 2007 05:55 Go to next message
Originally posted by: beat.strasser.inventage.com
Hi there
In our PDE build, we have to create our eclipse-based client *and* its
updatesite. There are plugins that have to be unpacked (especially
org.eclipse.equinox.launcher.(win32,gtk...)), but for the updatesite, we
need all of them packed in JAR files.
Our build currently jars everything for the update site (using the
property outputUpdateJars=true) and afterwards, it unpacks the features
and some plugins for a standalone client version.
The problem is that the build uses jar to build all the plugin/feature jar
files. But the JAR tool may change the MANIFEST file - and the plugin
signatures get corrupted. When I do the same thing directly with ZIP, the
signature is ok.
What's the preferred way to build an update site? We'd like to have valid
signatures, so our update mechanism and the about dialog work without
error.
Thanks for any hint,
Beat Strasser
Re: PDE Build: unpacked signed plugins get corrupted when jar-ing for updatesite [message #321554 is a reply to message #321534] Fri, 19 October 2007 11:48 Go to previous message
We do have an open bug about this in pde.build, the problem does come from the
Jar tool changing the manifest. https://bugs.eclipse.org/bugs/show_bug.cgi?id=196754
You should build for the update site first, using outputUpdateJars (like you are
doing) These are the jars that you should sign.
You can then re-package these jars using the packager
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_packager.htm
I think there is also an example in our slides from Eclipsecon
http://aniefer.blogspot.com/2007/08/pde-build-slides-from-ec lipsecon-2007.html
The one trick is that before doing the packaging, you would need to unjar only
the plugins that need to be in folder-form. The Eclipse build itself does this
using an UnpackUpdateJars task it provides in
org.eclipse.releng.basebuilder/plugins/org.eclipse.build.too ls.
-Andrew
Beat Strasser wrote:
> Hi there
> signature is ok.
> error.
> Beat Strasser
Previous Topic:Eclipse won't start up (Ubuntu 7.10 64-Bit)
Next Topic:How to suppress the 'Working Sets' menu item in an RCP?
Current Time: Thu Jul 17 07:39:44 EDT 2025
Powered by FUDForum. Page generated in 0.47194 seconds
