Home » Eclipse Projects » Nebula » CDateTime border
CDateTime border [message #32467] Thu, 05 April 2007 10:51 Go to next message
Originally posted by: bsimpson.mstc.state.ms.us
I'm using the CDateTime widget in an RCP app on a simple Composite
inside a WizardPage. It seems to function ok, but I can't get the usual
border to appear. I'm creating it like this:
CDateTime beginDT = new CDateTime(c, CDT.BORDER | CDT.DROP_DOWN |
CDT.DATE_SHORT | CDT.TAB_FIELDS);
If it matters, I'm using a GridLayout and setting the GridData like so:
GridDataFactory.fillDefaults().align(SWT.CENTER, SWT.CENTER).hint(70,
SWT.DEFAULT).applyTo(beginDT);
Normal Combos on the same Composite have their borders painted correctly.
Re: CDateTime border [message #32502 is a reply to message #32467] Thu, 05 April 2007 10:54 Go to previous messageGo to next message
Forgot to mention this is on WinXP, Eclipse 3.2.2, SWT 3.2.2
Re: CDateTime border [message #32537 is a reply to message #32502] Thu, 05 April 2007 12:01 Go to previous messageGo to next message
could you attach a small screenshot of the problem?
also, are you able to test it using a SWT 3.3 milestone?
(I don't have access to Windows, so I can't reproduce this directly)
thanks!
>> usual border to appear. I'm creating it like this:
Re: CDateTime border [message #32638 is a reply to message #32537] Mon, 09 April 2007 12:48 Go to previous messageGo to next message
--------------020502060900040001080407
Win32 screenshot attached.
I have not tried it with the SWT 3.3 milestone. I'll look into that and
get back with you.
> thanks!
>>> correctly.
Content-Type: image/png;
name="CDT_Win32.png"
Content-Disposition: inline;
filename="CDT_Win32.png"
iVBORw0KGgoAAAANSUhEUgAAAIEAAABwCAIAAAC2DIS7AAAACXBIWXMAAAsT AAALEwEAmpwY
AAAAB3RJTUUH1wQJECsCzz9QSAAAA65JREFUeNrtnTtu3DAQhqVgu5wjVQzE XXyElClyi6RI
mW6xnUsX9i1SpEy3WzqdAziVz+FaKQQQBEeiSIkUX98PFyu+dj0/50GKI/XP T48dSIo3iAAO
QPYcXF3fwIEpEfW3XXB6sxZkPYeDbwflw6+ub/DnsTj4+eu3LPzy+ZMkQ9Gg ZrHOkLqUtS7K
oTfW+bZ86dyPzwrH4/Hf3z/LenA8Ho0So9uickyqi6E6ikW93FHP5oaVvzwr nE4nD1tkF7qX
A/Cy9e6NJ1t6/exS/cHilLRoyfah1g1bbWy6widLsRqGqM349bD6H9YtuCEF VfL89KjXLspa
DrX4FRUohB8Hc/+tLDd8r/uYc5f2r2CdDOAADgAcwAHYMy7KfysmK8h9oTCx 6eVyQbguuL+7
jbhGO5/PDcrUaxvq2/cfcdfJXde9ffe1KQJeXx66rnv/4aNL48md0fAcNItI m7LERcSmYLUt
Gk2k3T28vjy05jl25UAXfWuy3nifKq5PVsqh0zNeKp4mP0z2UiUuOrcnJm9m pNEDKSmpGYsi
k73s42Sic2HvIIW0RfqEtUjckKPstThODghyFza8LVo3Q2WvUrxLqBt5UWJT OZH16S9VoWiF
SKkHhj8YJTtZYpnXll7tbIocApodu1Vx+TxZYm/MOhkktUWtYcWGaEQOGnGV OnxvCUTk4P7u
tsRDtdvhdV8sIgeZHytvwh+0qQHERXAA4AAOQPlrNMfDIAnhe2ooUoTa+jo5 3qmhMjjo+34Y
hnW1qbSheA7mxNr3/fjBpVZdWrrgD2YJWCRGkiRr9QZzYxIXOWnAdkO0m7Gq QQ/swhqGwW6L
9kHwU0M56sEoaGk9lIXRydjI6wokzL3dgwMl4sxdqHtONevkiJ7AeOhMhbHp pBClP7DX7qkN
FXIwJ0S7cGVtHeFQ2baoMqThwHfi143W9+yibsbBwTKinliBAyf45lpH2mGN yAHnMIiL4ADA
ARwAOIADAAddV9TDf9EDOABl7VUYjyfQrY370+LhYBMW33Th9eh+OKjczdbJ QaFzHJ+MHoR2
Bi5vZ8En7+ST5aXlVRXYIgAHcADgAA4AHBCbkp9c4/og4UQhPzkjbSieA/KT E3NAfnLiuIj8
5MR6UISwms5PHrP+VINUvLaen6w3SAjykz2mNvnJ4cU9WqHJ6Ij85PBGyat8 rpb8ZFAFB+Qn
p/cH+YD85MQgPzk9yE8GxEVwAOAADgAcFLBGy2Hl0jQHvP8pPQfE9fgDOAC7 4z9XQ735x+IP
EAAAAABJRU5ErkJggg==
--------------020502060900040001080407--
Re: CDateTime border [message #32673 is a reply to message #32537] Mon, 09 April 2007 14:45 Go to previous messageGo to next message
Tried the SWT 3.3 milestone 6, using eclipse-RCP-3.3M6-win32.zip as the
target for the RCP app that I'm using CDateTime in. Still no border on
the CDateTime widget.
(Incidentally, the dimensions of a wizard I was using are really wacked
out now, but that's a topic for another group, I suppose.)
> thanks!
>>> correctly.
Re: CDateTime border [message #32708 is a reply to message #32673] Tue, 10 April 2007 06:54 Go to previous messageGo to next message
this should be fixed in HEAD; let me know if it's still not right (is
the button's background correct?)
thanks!
>> thanks!
>>>> SWT.CENTER).hint(70, SWT.DEFAULT).applyTo(beginDT);
>>>> correctly.
Re: CDateTime border [message #32744 is a reply to message #32708] Tue, 10 April 2007 16:06 Go to previous messageGo to next message
I downloaded the latest version today (nebula_cdatetime_0.9.0) and I'm
having the same problem. The button looks ok, but I have no border.
My platform is Windows XP SP2.
Camilo Arango.
Re: CDateTime border [message #32827 is a reply to message #32744] Tue, 10 April 2007 16:20 Go to previous messageGo to next message
Hi Camilo,
Unfortunately, the fix is only in CVS right now.
Camilo Arango wrote:
> Hello,
> Camilo Arango.
Re: CDateTime border [message #32859 is a reply to message #32708] Tue, 10 April 2007 16:37 Go to previous messageGo to next message
--------------050501090300020403090806
I got the fix from CVS, rebuilt the widget's jar and plugin, got all my
package name problems straighted out (needed to remove "swt" from the
widget's package name in many places in my projects), and the border
looks fine now. (Back to using SWT 3.2, BTW.)
The only background issue I see is when the widget is disabled, there's
a white line at the top. See attached screenshot.
Thanks!
> thanks!
>> the target for the RCP app that I'm using CDateTime in. Still no
>> border on the CDateTime widget.
>> wacked out now, but that's a topic for another group, I suppose.)
>>> thanks!
>>>>> so:
>>>>> correctly.
name="CDT_Win32_disabled.png"
filename="CDT_Win32_disabled.png"
iVBORw0KGgoAAAANSUhEUgAAAIAAAAB9CAIAAADlUPxbAAAACXBIWXMAAAsT AAALEwEAmpwY
AAAAB3RJTUUH1wQKFBojULdAlgAABClJREFUeNrtnb1O3TAUx1N0N56DqUhl K4/AyMBb0KFj
t4iNkQHegoGRDUa6UYlO9znYO1zJcmPHsRMff/7+Qkg3cXyd8/PHseN78uXj /W1A+XSECQAA
AAQAq07PzgHwnznU33ar6cl6MPScdkGplct0enaO+yQC4PHp2Ux0dXlhklAM VP3V8aiP5lmf
ZqEn1mE7vnSu8EVpHMe/f34vtIBxHCdHJtcsNgtrQ5k0GoVQP+7ZwuayNUte lG5ubny7ILfF
gzr9oP7dP7E1ZVCxqxwDFiujo31sz2pdtm26oSsGYdOmk/6nT1d1t+5u9V57 YgJ15OP9TT+7
aGgzq8WvaKApBACYu1Xz+GSw9c9z7qP7K5gJIwAAAAEAAEjOCyp/maUomWs+ EdzQ19dXLOuj
+7tbqYnYy8tLhwYNWmL68fOX4Ex4GIbjk+uurP+5fxiG4eu37z6JreudkQF0 K6GlVrwg3NCl
5n/4L5R5lQBCi25N/7l/0P+CctPTB11eiNFLGQNqHM83PnSSAqBqlrLp5Mjh o9vin/sH/XJH
4uOT60MC9d/xpdaCTRL4VwXrw4n8LWBiONN81ju0GmhLJTD5OY5Yz4Yy2P5Y InILsJpDoguy
Yk6mKA9TowGYVL2gbqdexXokJ+iGSpu+DbS71bVeWUEfBq2DoUrgNpmZz4pO yc3GsySlAzBL
vzjk+hyZy8c/c0dKM431LDPh7sRinJdWLHNKAShwNi+t0CV+KQD3d7c17n7d rqAnXFIACt/5
3f4Y0GfdxwsCAAIAAFBVE7GG99D573fLPBNucg+d0GxAaimi/D10ovvd8gOo QnL73fIDqGXi
lr2ceEG9uqFuZ6mfnyPsUtraDPqhEjhO6ddOwMxdBQC7ca2GdlR281r98oit xDNGTJVdkPU2
dMtakSzevE+aLYUcx9HTR6pjDHh8eo5rMtGKcnj4kcZBOkp2e1eXF7E6DSGW hzxTWh831M4g
5eRAHEB0h1K6K0s8NdslqFOmK2k6M+rgZHxedGFxQ1c6QqvPNkai68U40VW2 cgFsaRARJbrd
ihawrNAnFkKDswgA0a1klXo76QCwhy4zAPbQMRMGAAIAABAAAIAAAIAYavgt P7SA5mbCoo1g
xYuBABBHPi8GogtCAAAAanAMWP1iIADEH4SHht7gQxcEAABgAgAAAAGAeUA0 ESsi/zyAWBH5
J2LEimhtJiwhYkVU1g7wgnBD8zlLrTpX+WNFWM/2Ez0ic6wI69n00SP6jRVh PZs+ekTGWBGJ
3NBDFXP3Knl7D/03yd3FitgeSSLKz+eJFZFf3cWKiOJcxo0e0VesCGs0iK6i R5QYK6Kr6BHE
iugPQGiFFargxIrILGJFZBaxIpAMAGJFMBMGAAIAABAAKvWCSpig9wsALz4z ALx4xgAAIAAA
AAEAACiB/gEUs9imrVmNXgAAAABJRU5ErkJggg==
--------------050501090300020403090806--
Re: CDateTime border [message #32929 is a reply to message #32827] Thu, 12 April 2007 17:30 Go to previous messageGo to next message
Hi Jeremy,
When would be the next jar release out?
Camilo Arango
Re: CDateTime border [message #33398 is a reply to message #32827] Fri, 27 April 2007 00:42 Go to previous messageGo to next message
Originally posted by: reg.hill-labs.co.nz
Sorry to be daft...
But where do I find the nebula project in CVS?
Have looked under the /cvsroot/eclipse but can't seem to find it.
Colin
Re: CDateTime border [message #33430 is a reply to message #33398] Fri, 27 April 2007 00:50 Go to previous messageGo to next message
Sorry... I was daft... spent ages looking then a few minutes later
realised I should be looking in /cvsroot/technology (still a bit new at
this :-))
Colin
Re: CDateTime border [message #35031 is a reply to message #32929] Thu, 17 May 2007 16:09 Go to previous message
It's been a month now since my last post. Do you think the next jar will
be posted soon?
Camilo Arango.
Re: CDateTime border [message #580761 is a reply to message #32467] Thu, 05 April 2007 10:54 Go to previous message
Re: CDateTime border [message #580780 is a reply to message #32502] Thu, 05 April 2007 12:01 Go to previous message
thanks!
Re: CDateTime border [message #580879 is a reply to message #32537] Mon, 09 April 2007 12:48 Go to previous message
get back with you.
> thanks!
>>> correctly.
Re: CDateTime border [message #580905 is a reply to message #32537] Mon, 09 April 2007 14:45 Go to previous message
> thanks!
>>> correctly.
Re: CDateTime border [message #580916 is a reply to message #32673] Tue, 10 April 2007 06:54 Go to previous message
thanks!
>> thanks!
>>>> correctly.
Re: CDateTime border [message #580930 is a reply to message #32708] Tue, 10 April 2007 16:06 Go to previous message
Camilo Arango.
Re: CDateTime border [message #580940 is a reply to message #32744] Tue, 10 April 2007 16:20 Go to previous message
Hi Camilo,
> Hello,
> Camilo Arango.
Re: CDateTime border [message #580971 is a reply to message #32708] Tue, 10 April 2007 16:37 Go to previous message
Thanks!
> thanks!
>>> thanks!
>>>>> so:
>>>>> correctly.
Re: CDateTime border [message #581002 is a reply to message #32827] Thu, 12 April 2007 17:30 Go to previous message
Hi Jeremy,
Camilo Arango
Re: CDateTime border [message #581265 is a reply to message #32827] Fri, 27 April 2007 00:42 Go to previous message
Sorry to be daft...
Colin
Re: CDateTime border [message #581298 is a reply to message #33398] Fri, 27 April 2007 00:50 Go to previous message
this :-))
Colin
Re: CDateTime border [message #582417 is a reply to message #32929] Thu, 17 May 2007 16:09 Go to previous message
be posted soon?
Camilo Arango.
Previous Topic:[CompositeTable] UI and design questions
Next Topic:[GridViewer]How to change text of rowHeader with a labelprovider ?
Current Time: Mon Sep 01 06:58:18 EDT 2025
Powered by FUDForum. Page generated in 0.08795 seconds
