Home » Archived » BIRT » "Newbie" Help -- Development with Milestones / Custom Data Sources
"Newbie" Help -- Development with Milestones / Custom Data Sources [message #32445] Mon, 02 May 2005 11:50 Go to next message
Originally posted by: raetta.towers.embeddedplus.com
Hi all,
First of all, thanks to all the developers making this project work. I am
new to both developing on the Eclipse platform and the open source community
and am very impressed with the project overall.
I have a few basic conceptual issues regarding development of a custom ODA
data source... If I have done everything correctly, is it true that I should
be able to test my adapter with source code from one of the stable releases
(as opposed to attempting to use the code from the CVS source) and see my
new data source listed?
If it is true, then are the following steps all I need to do in order to
corectly implement a custom ODA driver?
1. implement ODA interfaces as is done for the flatfile
(i assume that I do not need to implement the UI plugin just to get a
data source)
2. in the plugin.xml file for my driver, have the following jar files
listed in the requires section:
org.eclipse.ui
org.eclipse.birt.core
org.eclipse.birt.data
org.eclipse.birt.data.oda
3. in the plugin.xml file for my driver, have as an extension point:
org.eclipse.birt.data.oda.odaDriverRuntime
(just as in the plugin.xml file for the flatfile)
I realize that there are tutorials on the way that will speak to this
subject... however, from past posts it seems like there are developers out
there who might know the answers? I'm a little new to the whole environment
and would appreciate any help I can get!!
Thanks alot,
Raetta
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #32916 is a reply to message #32445] Mon, 02 May 2005 17:56 Go to previous messageGo to next message
Hi again,
Well, to anyone reading this thread... earlier I made an incorrect
assumption... The reason I did not see my data sources inside the data
source browser is because I had not implemented a gui component (i.e.: I had
not created a ui -plugin.)
Should have been self-evident, I suppose!!
Raetta
"raetta" <raetta.towers@embeddedplus.com> wrote in message
news:d55igg$4d3$1@news.eclipse.org...
> Hi all,
> community and am very impressed with the project overall.
> should be able to test my adapter with source code from one of the stable
> releases (as opposed to attempting to use the code from the CVS source)
> and see my new data source listed?
> data source)
> org.eclipse.ui
> out there who might know the answers? I'm a little new to the whole
> environment and would appreciate any help I can get!!
> Thanks alot,
> Raetta
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #33330 is a reply to message #32916] Tue, 03 May 2005 02:45 Go to previous messageGo to next message
Hey !
Well, I'm a newer newbie than you. Could you please list out some
tutorials on ODA and custom data sources for me?
Thank you,
Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #33502 is a reply to message #33330] Tue, 03 May 2005 12:39 Go to previous messageGo to next message
Hi Pavithra,
Actually, there are currently no tutorials for this subject online. From
past posts to the newsgroup I know that the primary developers are working
on tutorials as time permits. I learned how to implement custom data sources
from downloading and attempting to build the CVS source code. If you decide
to download the source code, pay attention to the plug-ins for the jdbc and
flatfile drivers:
org.eclipse.birt.report.data.oda.flatfile
org.eclipse.birt.report.data.oda.flatfile.ui
org.eclipse.birt.report.data.oda.jdbc
org.eclipse.birt.report.data.oda.jdbc.ui
These plug-ins will give you a good idea of how you should implement your
custom data sources. Note that the CVS source changes frequently, so my
advice is to download a stable milestone build for development and testing,
while keeping the CVS source code for a reference.
Hope that helps you get started a bit!
Raetta
"Pavithra" <pavithra@optena.com> wrote in message
news:98c825ff1103d1efab84a3f2b4b952f6$1@www.eclipse.org...
> Hey !
> Thank you,
> Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #33674 is a reply to message #33502] Tue, 03 May 2005 17:02 Go to previous messageGo to next message
Pavithra & Raetta,
We are in the process of creating an ODA tutorial and of finalizing some
revisions to the ODA framework itself. We may have something on the web site
in the next couple of weeks. I'll post partial material sooner if possible.
- Paul
Paul Rogers
BIRT PMC
news:d589pk$g4r$1@news.eclipse.org...
> Hi Pavithra,
> sources from downloading and attempting to build the CVS source code. If
> you decide to download the source code, pay attention to the plug-ins for
> the jdbc and flatfile drivers:
> testing, while keeping the CVS source code for a reference.
> Raetta
>> Hey !
>> Thank you,
>> Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #34100 is a reply to message #33674] Wed, 04 May 2005 01:17 Go to previous messageGo to next message
Paul and Raetta,
Thanks a load !! Well,I have another query,I'd like to set up a Java
object as a data source, is that supported currently? Do we have ODA
drivers for POJO similar to flatfiles that I could implement?
Thanks again,
Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #34134 is a reply to message #34100] Wed, 04 May 2005 02:01 Go to previous messageGo to next message
Okay, I gather from previous posts that I should be using scripting to call
POJOs. Are scripted data sources available yet ?
Thank you,
Pavithra
news:d2d7a3193997c3fce779e83455afa07f$1@www.eclipse.org...
> Paul and Raetta,
> Thanks again,
> Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #34408 is a reply to message #34100] Wed, 04 May 2005 18:36 Go to previous messageGo to next message
Pavithra,
Good timing! Milestone 3 is just out and it provides the scripted data set
feature that is the simplest way to integrate with POJOs. No example yet,
but its on the list to provide.
There is not yet an ODA driver for POJOs, though this would be a perfect
area where community members could contribute. (Hint, hint...)
- Paul
Paul Rogers
BIRT PMC
> Paul and Raetta,
> Thanks again,
> Pavithra
Re: "Newbie" Help -- Development with Milestones / Custom Data Sources [message #54803 is a reply to message #34408] Thu, 07 July 2005 08:38 Go to previous message
Hi Paul,
I did some performance testing using 4000 POJOS and copying its values into
the scripted variables. Unfortunately the fetch method took about 3 minutes
to copy some values from my POJOS into the javascript variables.
new Packages.package.EmployeeDAO().getEmployees();
while(results.hasNext()){
employee = results.next();
row.name = employee.name;
row.department = employee.position.unity.department;
I guess a solution could be writing a proper ODA driver for Pojos...
"Paul Rogers" <progers@actuate.com> wrote in message
news:d5bj50$gu0$1@news.eclipse.org...
> Pavithra,
> - Paul
> Paul Rogers
> BIRT PMC
>> Paul and Raetta,
>> Thanks again,
>> Pavithra
Previous Topic:How to include browser javascript in my report?
Next Topic:PDF format with ReportRunner
Current Time: Mon Sep 01 06:59:45 EDT 2025
Powered by FUDForum. Page generated in 0.11189 seconds
