OHF IHE Component 2007/2008 Branch [message #32419] |
Fri, 20 July 2007 20:46 |
Greetings,
The OHF IHE components, including those contained in
org.eclipse.ohf.ihe.* and org.eclipse.ohf.bridge.*, have been branched
to prepare for 2008 IHE updates. If you are actively building the IHE
components from source, please be aware of the following changes:
The active development stream at the trunk is code for 2007-2008 IHE
profiles. It is unstable until further notice. All changes to reflect
2007 change proposals (to be ratified shortly) as well as new profile
implementations will be checked in here. This code is targeted for
testing at the 2008 IHE Connectathons and may not be compliant with IHE
2006-2007 infrastructure.
For IHE implementations from the 2006-2007 cycle, including code tested
at the 2007 Connectathons, please check out from the branch
OHF_IHE_2007_BRANCH. This branch is considered stable and will only be
updated for critical bug fixes. It has been extensively tested with
-Matt
FUDForum. Page generated in 0.02747 seconds
