small bug in CDO [message #32405] |
Thu, 20 April 2006 17:54  |
Eike,
Found a small bug in the new CDO.
In ClassInfoImpl.java you call getEAttributes() where you should call
getEAllAttributes() so that the super class attributes are returned also.
Mark.
Re: small bug in CDO [message #575883 is a reply to message #32405] |
Fri, 21 April 2006 07:45  |
--------------090701040806040807000303
Mark,
You should report bugs using bugzilla. Here's a link that gets you most
of the way to the right place.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT
Use either CDO or Net4j as the components (whichever is most
appropriate) so it ends up on Eike's list.
Geib wrote:
> Eike,
> Mark.
<html>
<head>
http-equiv="Content-Type">
</head>
Mark,<br>
<br>
Re: small bug in CDO [message #576033 is a reply to message #32612] |
Sat, 22 April 2006 08:50  |
Mark,
As I also told you in your Email, I'll be able to look at this issue, when
I'm back in Berlin. That will be on Thursday.
Cheers
/Eike
FUDForum. Page generated in 0.04432 seconds
