Home » Eclipse Projects » Eclipse Platform » enablement and project facets?
enablement and project facets? [message #320090] Tue, 11 September 2007 14:37
Originally posted by: nadeem.aboobaker.bea.com
Hi All,
I was wondering if there's anyway to make the enablement clause in
plugin.xml use a project's facet?
For example, in the org.eclipse.ui.navigator.navigatorContent extension
point when specifiying a commonWizard, or in the org.eclipse.ui.decorators
extension point, or any other enablement clause that can be specified in the
plugin.xml.
I know in the case of the decorators extension point, I can specify an
instance of ILightWeightLabelProvider and do the facet checking in code.
However, I don't want to implement different ways of checking the facet if
there's one supported way that can be used in the enablement clause.
Thanks for any help!
Nadeem
Previous Topic:QuickDiff Action null pointer error openning an editor
Next Topic:How to save a programmatically defined Command?
Current Time: Tue Jul 22 15:37:12 EDT 2025
Powered by FUDForum. Page generated in 0.05267 seconds
