Home » Eclipse Projects » Eclipse Platform » Ddevelopment of new Extension - not picked up by run-time workbench
Ddevelopment of new Extension - not picked up by run-time workbench [message #319833] Mon, 03 September 2007 14:18 Go to next message
Originally posted by: martin.tomcat.org
Hi Forum
So finally I have the need to create my own extension point!
But I can not get the my new extension point to be picked up by the
runt-time workbench.
But if I simply export the plug-in to the plugin directory it is picked up
(after restart of Eclipse)
Am I doing something wrong or is this as expected.
BR
M
Re: Ddevelopment of new Extension - not picked up by run-time workbench [message #319839 is a reply to message #319833] Tue, 04 September 2007 03:19 Go to previous messageGo to next message
Martin wrote:
>Hi Forum
Make sure to use -clean and check the .log for potential problems.
Dani
>BR
>M
Re: Ddevelopment of new Extension - not picked up by run-time workbench [message #319895 is a reply to message #319833] Wed, 05 September 2007 10:46 Go to previous message
Martin wrote:
> Hi Forum
Cannot be picked up by the runtime workbench in what way? Do you mean
you launch a runtime workbench and you cannot see your extension point
if you try and use it? If so that's a known limitation.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Contributing To Eclipse
Next Topic:Key Binding Issue
Current Time: Fri Jul 18 02:09:42 EDT 2025
Powered by FUDForum. Page generated in 2.62304 seconds
