Home » Eclipse Projects » Eclipse Platform » Red box w/white X decorator in Synchronize view?
Red box w/white X decorator in Synchronize view? [message #319678] Wed, 29 August 2007 17:28 Go to next message
Originally posted by: jay+news.jay.fm
Under my Team Synchronize perspective, in the Synchronize view, two of my
projects' top-level folders (both RadRails projects) are decorated with a
white X in a red box. I've googled incessantly but can't find out what
that means, and Mark from Subclipse says it's not Subclipse doing it. It
doesn't show in any other view that I can find. Anyone have an idea?
Corollary: I got the impression from reading the API that decorators have
a description field that's supposed to be displayed when you hover over
them. That doesn't work for me; has it ever worked? Is there another way
to see who's providing a given decorator?
Mac OS X 10.4.10, Eclipse Europa, Aptana M9, RadRails M5, Subclipse 1.2.4,
fully updated
Jay Levitt
Re: Red box w/white X decorator in Synchronize view? [message #319761 is a reply to message #319678] Thu, 30 August 2007 17:41 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
> my projects' top-level folders (both RadRails projects) are decorated
> with a white X in a red box. I've googled incessantly but can't find
> out what that means, and Mark from Subclipse says it's not Subclipse
> doing it. It doesn't show in any other view that I can find. Anyone
> have an idea?
Is it the same decorator that appears on a file/class/element with build
(compile) errors? New in 3.3 (I think) the Synchronize view shows error
markers just like other views.
Hope this helps,
Eric
Re: Red box w/white X decorator in Synchronize view? [message #319780 is a reply to message #319761] Fri, 31 August 2007 08:25 Go to previous messageGo to next message
>> have an idea?
Ah hah! Thanks, that was the clue. I'm using Ruby, so there shouldn't be
any compile errors - or so I thought. Turns out RDT/RadRails actually
does decorate files with a syntax error, but for some reason that
decoration doesn't show up in Navigator. Project Explorer (which I have
no use for) DOES display it, however, and so does Team Synchronize.
Re: Red box w/white X decorator in Synchronize view? [message #319782 is a reply to message #319780] Fri, 31 August 2007 09:48 Go to previous message
Originally posted by: markphip.GoogleMail.com
In article
<64eadfdb2ffe595ddc302f8a1e0486ea$1@www.eclipse.org>jay+news@jay.fm
(Jay Levitt) wrote:
> Eric Rizzo wrote:
>>> two of my projects' top-level folders (both RadRails projects) are
>>> decorated with a white X in a red box. I've googled incessantly
>>> but can't find out what that means, and Mark from Subclipse says
>>> it's not Subclipse doing it. It doesn't show in any other view
>> build (compile) errors? New in 3.3 (I think) the Synchronize view
>> shows error markers just like other views.
> shouldn't be any compile errors - or so I thought. Turns out
> RDT/RadRails actually does decorate files with a syntax error, but
> for some reason that decoration doesn't show up in Navigator. Project
> Explorer (which I have no use for) DOES display it, however, and so
The Navigator view does not show these decorations for Java files
either,so RDT is not alone.
This explains why you were confused though. When you
previouslymentioned Navigator, I was just thinking you meant a view
provided by
RDT.
Mark
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Previous Topic:Eclipse Java template
Next Topic:Owner-Draw Table: cell-height immutable?
Current Time: Sun Aug 31 18:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.04736 seconds
