Home » Eclipse Projects » Eclipse Platform » Uncaught Runtime Exceptions
Uncaught Runtime Exceptions [message #319099] Sat, 11 August 2007 16:47 Go to next message
I have been using a couple of my own Runtime exceptions, LogicError and
DataIntegrity error(both of which extend RuntimeException), for catching
programming errors.
In 3.1 they did what I expected, that is, when thrown they terminated
execution and offered a stack trace showing the Exception message.
In 3.2.2 that is not happening. A dialog pops up, says a LogicException
has occurred, but does not show the exception's message or offer a
stack trace (the details >> page shows the same cryptic info).
1. Is there a way to obtain the stack trace when your code throws
runtime exceptions?
2. Is there a way to handle uncaught exceptions in your application,
that is, can one plug in a custom uncaught-exception handler?
I've searched the online help, google, and my books, with no luck,
Bill.
Re: Uncaught Runtime Exceptions [message #319100 is a reply to message #319099] Sat, 11 August 2007 16:49 Go to previous messageGo to next message
> programming errors.
> runtime exceptions?
> Bill.
Sorry, the problem I'm having is on 3.3, not 3.2.2, Bill
Re: Uncaught Runtime Exceptions [message #319122 is a reply to message #319100] Mon, 13 August 2007 09:16 Go to previous message
In 3.3 new status handling (error handling) was introduced, which is
probably why you are seeing the difference.
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench_statushandling.htm
There are ways to plug your own handlers into the status framework.
Paul Webster
Previous Topic:standaloneUpdate gives strange return code
Next Topic:Extending the CVS plugin
Current Time: Sat Nov 15 06:01:27 EST 2025
Powered by FUDForum. Page generated in 0.04151 seconds
