Eclipse crashes [message #319041] |
Fri, 10 August 2007 06:33  |
Originally posted by: morten.bilpriser.dk
I have tried Eclipse 3.3 for a few days, and it crashes quite often.
There are generally two ways it crashes:
1. I select a folder in the navigator window and press CTRL + H in order to
search within that folder. Then a message box appears saying "Pure Virtual
Function R6025" when I click Okay to that box Eclipse closes.
There is always this line in the resulting hs_err file:
j
org.eclipse.swt.internal.win32.OS.CreateWindowExW(I[C[CIIIII IIILorg/eclipse/swt/internal/win32/CREATESTRUCT;)I+0
2. It sometimes crashes when I choose "Open Call Hierarchy".
I'm on Windows XP-SP2, Java 1.6.0_02.
Morten
Re: Eclipse crashes [message #319047 is a reply to message #319041] |
Fri, 10 August 2007 07:26  |
Morten,
You might try a different JVM. If the problem is consistently
reproducible following a particular set of steps, then you should open a
bugzilla with all the details.
Morten wrote:
> Hi
> j
> Best regards,
> Morten
FUDForum. Page generated in 0.50238 seconds
