| CommonNavigator and Properties View [message #319020] |
Thu, 09 August 2007 16:48 |
Originally posted by: francois.malouin.polymtl.ca
Hello, I am using the Common Navigator Framework to display some resources
in my plugin.
Now I'd like to use the properties view to show some info about the selected
elements in the tree.
I found out that the CommonNavigator works with the
"org.eclipse.ui.views.properties.tabbed" plugin...and there comes my
problem.
If I start my plugin without "org.eclipse.ui.views.properties.tabbed", my
properties are simply displayed in the simpler two-column default view...and
everything works great...but when I active the tabbed thingy...I get an
error when selecting anything in my view...
"contributor xyz.myNavigatorView cannot be created"
Where xyz.myNavigatorView extends CommonNavigator...
I don`t want to use the tabbed properties, I just don't need them...so is
there a way I can get the selection to ALWAYS use the simple properties
view, even if the tabbed plugin is loaded??
Thanks a lot,
Fran
FUDForum. Page generated in 0.03534 seconds
