Home » Eclipse Projects » Eclipse Platform » PDE versions in update site
PDE versions in update site [message #318201] Mon, 23 July 2007 11:27 Go to next message
I'm working on a Eclipse plugin and I'm a bit confused with the version
numbering if the update site of the feature.
I have in my update site those features:
myPlugin_0.0.0.200707171016
myPlugin_0.1.0.200707231655
If I try to install my feature from my update site, I can only see the 2nd
one even if I uncheck the option "Show latest version of the feature only".
I'd like to be able to choose between the two versions. What shall I do ?
Tex.
Re: PDE versions in update site [message #318211 is a reply to message #318201] Mon, 23 July 2007 13:01 Go to previous messageGo to next message
Your site.xml file needs to specify both versions of your feature,
preferredly under different categories.
HTH,
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Tex Twil wrote:
> Hello,
> 2nd one even if I uncheck the option "Show latest version of the feature
> only". I'd like to be able to choose between the two versions. What
> shall I do ?
> Tex.
Re: PDE versions in update site [message #318255 is a reply to message #318211] Tue, 24 July 2007 03:09 Go to previous messageGo to next message
it does specify both of them. They are in the same cathegory.
<site>
<feature url="features/myFeature_0.0.0.200707171016.jar" id="my_Feature"
version="0.0.0.200707171016">
<category name="SpliceSEC Modeling Tool"/>
</feature>
<feature url="features/myFeature_0.1.0.200707231655.jar" id="my_Feature"
version="0.1.0.200707231655">
<category name="My Modeling Tool"/>
</feature>
<category-def name="My Modeling Tool" label="My Modeling Tool"/>
</site>
The version 0.0.0 appears light gray in the site.xml editor.
Tex.
"Martin Oberhuber" <martin.oberhuber@windriver.com> a écrit dans le message
de news:f82mu3$mjc$1@build.eclipse.org...
> HTH,
> Martin Oberhuber
> Tex Twil wrote:
>> Hello,
>> only". I'd like to be able to choose between the two versions. What shall
>> I do ?
>> Thanks,
>> Tex.
Re: PDE versions in update site [message #318257 is a reply to message #318255] Tue, 24 July 2007 03:12 Go to previous messageGo to next message
.... if I put them in different categories, the poblem is the same. Only the
lastest version is visible.
Tex.
"Tex Twil" <chaljan@hotmail.com> a écrit dans le message de
news:f848j3$rtj$1@build.eclipse.org...
> Hello,
> <site>
> </feature>
> </feature>
> </site>
> Tex.
> message de news:f82mu3$mjc$1@build.eclipse.org...
>> HTH,
>> Martin Oberhuber
>> Tex Twil wrote:
>>> Hello,
>>> shall I do ?
>>> Thanks,
>>> Tex.
Re: PDE versions in update site [message #318261 is a reply to message #318257] Tue, 24 July 2007 04:15 Go to previous message
Hello ... again :)
I found out what was the problem. In my site.xml I was referencing two
different version and in the directory "features" where three of them. I
don't know where the 3rd comes from but this was apparently confusing the
update manager.
Now it works,
bye Tex.
news:f848ov$snj$1@build.eclipse.org...
> the lastest version is visible.
> Tex.
>> Hello,
>> <site>
>> id="my_Feature" version="0.0.0.200707171016">
>> </feature>
>> id="my_Feature" version="0.1.0.200707231655">
>> </feature>
>> </site>
>> Thanks,
>> Tex.
>>> HTH,
>>> Martin Oberhuber
>>> Tex Twil wrote:
>>>> Hello,
>>>> feature only". I'd like to be able to choose between the two versions.
>>>> What shall I do ?
>>>> Thanks,
>>>> Tex.
Previous Topic:Eclipse hang during "Find and Install"
Next Topic:InstanceScope prefs do not inherit from DefaultScope prefs
Current Time: Sat Nov 08 06:57:50 EST 2025
Powered by FUDForum. Page generated in 0.03839 seconds
