| PDE - change qualifier [message #317668] |
Wed, 11 July 2007 11:05  |
this is a question about plug-in deployement and Im not sure if I'm in the
right newsgroup.
During a build of a feature I use the "qualifier" for version numbering.
The "qualifier" is replaced by YYYYMMDDHHMM. I'd like to change it so it
doesn't append hours and minutes to the version number i.e. YYYYMMDD.
Where can I do this ?
Thank you,
Tex.
| Re: PDE - change qualifier [message #317759 is a reply to message #317702] |
Thu, 12 July 2007 10:17  |
There are some docs on fetching from a repository here:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_fetch_phase.htm
Note however, that SVN is not supported by default. There is however, an
extension point for other repos, and someone wrote an SVN plugin which you can
find here: (there may be others I don't know of)
http://sourceforge.net/projects/svn-pde-build/
The specific format of the map files for SVN will be dependent on that plug-in.
-Andrew
Tex Twil wrote:
> yes my project is on a SVN server. Can you point me to this map file
> 'cos I dont really know what it is.
> thanks,
> Tex.
> Andrew Niefer wrote:
>> Tex,
>> If you are using map files to fetch your features out of cvs (or some
>> other repository) then the Tag from the map files will be used in the
>> qualifier.
>> If you are not doing that, there are 2 other ways to set the qualifier:
>> 1) In the feature's build.properties, set qualifier=YYYYMMDD
>> 2) In the build configuration build.properties set
>> forceContextQualifier=YYYYMMDD
>> I would suggest method (2), which can also be achieved by adding
>> -DforceContextQualifier=YYYYMMDD to your command line
>> -Andrew
>> Tex Twil wrote:
>>> Hello,
>>> in the right newsgroup.
>>> numbering. The "qualifier" is replaced by YYYYMMDDHHMM. I'd like to
>>> change it so it doesn't append hours and minutes to the version
>>> Thank you,
>>> Tex.
FUDForum. Page generated in 0.03689 seconds
