Custom Eclipse Launcher [message #316678] |
Thu, 14 June 2007 13:17  |
Originally posted by: pecze.nospam.us.ibm.com
I'm attempting to create an executable to launch my eclipse based
application.
All the exe does is use java to launch eclipse. I have it mostly
working, however, I can't get my splash screen to display.
I'm running the following command:
java -Xms40m -Xmx256m -jar "C:\MyDirectory\startup.jar" -os win32 -ws
win32 -arch x86 -launcher "C:\MyDirectory\mylauncher.exe" -configuration
"C:\MyDirectory\configuration" -showsplash 600 -vm
"C:\MyDirectory\_jvm\jre\bin\javaw" -vmargs -Xms40m -Xmx256m -jar
config.ini sets eclipse.product and osgi.splashPath
My product branding gets displayed properly, but not the splash screen.
When I run via eclipse.exe, the splash screen gets displayed. I'm not
sure what I'm doing wrong.
Shawn
Re: Custom Eclipse Launcher [message #316829 is a reply to message #316703] |
Tue, 19 June 2007 15:18  |
I'm using Eclipse 3.2.1
Andrew Niefer wrote:
> Shawn,
> Which version of eclipse are you using, because the launcher was
> rewritten in 3.3 and launching has changed a lot.
> Since you have a startup.jar, does that mean your are using 3.2?
> Note that it is the launcher itself that displays the splash screen. In
> 3.2 Main will exec your launcher again with a command line something like
> mylauncher.exe -showsplash 600 <path/to/splash.bmp>
> You launcher is expected to show the splash screen (its a new process).
> The eclipse.exe also listens on stdin for commands to show a progress
> bar and display text.
> 3.2 source for the launcher is in cvs under platform-launcher/library
> -Andrew
>> application.
>> -configuration "C:\MyDirectory\configuration" -showsplash 600 -vm
>> Thanks,
>> Shawn
FUDForum. Page generated in 0.04979 seconds
