BundleError while adding a preferencePage [message #314603] |
Wed, 18 April 2007 08:06 |
Originally posted by: swetha.atc.tcs.com
I created a plugin project with Template using a PreferencePage..
Now I replaced the preferenePage with my own class that extends
PreferencePage..
Also changed the plugin.xml appropriately...
<extension
point="org.eclipse.ui.preferencePages">
<page
name="Sample Preferences"
class="se.preferences.PropertyPreferencePage"
id="se.preferences.PropertyPreferencePage">
</page>
</extension>
When I run the Eclipse app,click on Window->Preferences and click on the
Sample Preferences node ,I get the following error message..
org.osgi.framework.BundleException: Bundle
"org.eclipse.update.configurator" version "3.2.100.v20061214" has already
been installed from:
update@plugins/org.eclipse.update.configurator_3.2.100.v20061214.jar
org.eclipse.osgi.framework.internal.core.Framework.createAnd VerifyBundle(Framework.java:642)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:909)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:824)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:875)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:819)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:229)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1032)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:609)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:296)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:165)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
at org.eclipse.equinox.launcher.Main.main(Main.java:1099)
Am I missing something ...
Swetha
FUDForum. Page generated in 1.07005 seconds
