Home » Eclipse Projects » Eclipse Platform » Simulate document change
Simulate document change [message #314058] Mon, 02 April 2007 14:28 Go to next message
Originally posted by: gritgop.pisem.net
Hello.
I have an editor that reads a java file and, in response to the user
actions, creates an underlying model that later has to be saved to a
file. Since the source code is never changed, I have the problem that
when I close the editor, Eclipse does not tell me that the file was
changed and needs to be saved. Is there a way so send a message to the
editor so it believes that the file was modified and needs to be saved?
Thank you.
Re: Simulate document change [message #314082 is a reply to message #314058] Tue, 03 April 2007 02:48 Go to previous message
exquisitus wrote:
> Hello.
Why not just overwrite the corresponding methods in the editor and force
the save? Note that you also need to save when the input of the editor
changes.
Dani
> Thank you.
Previous Topic:Selection event on viewer and MultiPageEditorPart
Next Topic:Eclipse Platform 3.2.1 Patch issues
Current Time: Sun Nov 23 09:40:25 EST 2025
Powered by FUDForum. Page generated in 0.03872 seconds
