| FrameworkEvent.ERROR when starting eclipse on Mac OS X [message #314023] |
Sat, 31 March 2007 16:01 |
Originally posted by: enterprise.zonnet.nl
Hi, I can't seem to start eclipse.
I'm trying to run it on mac os x tiger. I have used it in the past a
couple of times without problems on the same powerbook.
Now I need it again and I downloaded the newest version, unpacked it and
double clicked on the icon, I get the splash screen and then "An error
has occurred see the log file". I have googled the the problem, read a
ton of forum threads and came to the conclusion that alot of people who
experience similar problems are trying to copy their config.ini files or
have written their own plugins which don't work and cause errors.
I am trying neither, this is a clean install. I am not trying anything
funky or weird. I can't get it to start and it is driving me nuts.
I have reinstalled java, to no avail. Java btw. is working properly.
I tried starting eclipse with "-clean", also didn't work.
The following is my system:
Mac OS X 10.4.9 PPC
Eclipse 3.2 eclipse.buildId=M20070212-1330
java.version=1.5.0_07 (Appel version)
This is the output from -debug
Start VM: /usr/bin/java
-XstartOnFirstThread
-jar /Users/alexanderhaven/Eclipse/eclipse/./startup.jar
-os macosx
-ws carbon
-launcher /Users/alexanderhaven/Eclipse/eclipse/./eclipse
-name Eclipse
-showsplash 600
-exitdata 30000
-debug
-vm /usr/bin/java
-vmargs
Install location:
file:/Users/alexanderhaven/Eclipse/eclipse/
Configuration file:
file:/Users/alexanderhaven/Eclipse/eclipse/configuration/con fig.ini
loaded
Configuration location:
Framework located:
file:/Users/alexanderhaven/Eclipse/eclipse/plugins/org.eclip se.osgi_3.2.2
..R32x_v20070118.jar
Framework classpath:
Splash location:
/Users/alexanderhaven/Eclipse/eclipse/plugins/org.eclipse.pl atform_3.2.2.
r322_v20070117b/splash.bmp
runCommand:
</Users/alexanderhaven/Eclipse/eclipse/./eclipse><-name><Eclipse ><-showsp
lash><600>< /Users/alexanderhaven/Eclipse/eclipse/plugins/org.eclipse.pl at
form_3.2.2.r322_v20070117b/splash.bmp>
Debug options:
file:/Users/alexanderhaven/Eclipse/eclipse/.options not found
Time to load bundles: 201
runCommand:
</Users/alexanderhaven/Eclipse/eclipse/./eclipse><-name><Eclipse ><-exitda
ta><30000><An error has occurred. See the log file
/Users/alexanderhaven/Eclipse/eclipse/configuration/11753708 17354.log. >
And this is the log it self
!ENTRY org.eclipse.update.configurator 4 0 2007-03-31 21:53:40.466
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start()
of bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator
(BundleContextImpl.java:1010)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleCo
ntextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHos
t.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBu
ndle.java:329)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework
..java:1046)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(
StartLevelManager.java:573)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartL
evelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLeve
l(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(
StartLevelManager.java:455)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManag
er.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventMan
ager.java:291)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.jav
a:85)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initializ
e(ConfigurationActivator.java:113)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(Con
figurationActivator.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleCo
ntextImpl.java:991)
(BundleContextImpl.java:985)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
a:85)
ntextImpl.java:991)
ntextImpl.java:966)
t.java:317)
ndle.java:329)
..java:1046)
er.java:189)
ager.java:291)
!ENTRY org.eclipse.core.runtime 4 0 2007-03-31 21:53:40.529
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
t.java:294)
ndle.java:329)
..java:1046)
er.java:189)
ager.java:291)
!ENTRY org.eclipse.osgi 4 0 2007-03-31 21:53:40.545
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x
_v20070111.jar/ is not active.
!ENTRY org.eclipse.osgi 4 0 2007-03-31 21:53:40.548
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.j
ar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2007-03-31 21:53:40.592
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips
eAppLauncher.java:65)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:4
00)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1
77)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java
:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorI
mpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2007-03-31 21:53:40.629
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-31 21:53:40.632
!MESSAGE Bundle
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-03-31 21:53:40.633
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
org.eclipse.equinox.preferences_[3.2.0,4.0.0).
org.eclipse.equinox.registry_[3.2.0,4.0.0).
org.eclipse.core.contenttype_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2007-03-31 21:53:40.641
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-31 21:53:40.641
!MESSAGE Bundle
ar/ [3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-03-31 21:53:40.642
!MESSAGE Missing optionally required bundle
org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
Please help.
FUDForum. Page generated in 0.03616 seconds
