Home » Eclipse Projects » Eclipse Platform » [DataBinding] Cascading comboviewers
[DataBinding] Cascading comboviewers [message #313420] Wed, 14 March 2007 16:38 Go to next message
Originally posted by: smithbb+eclipse-news.gmail.com
Hi All,
I have a scenario where I have:
class Organisation
String name;
List<OrgUnit> orgUnits; //parent -> child
class OrgUnit
String name;
Organisation org; //child -> parent
class FactoryWorker
String name;
OrgUnit orgUnit;
For the UI I have:
FactoryWorker Form
Organisation: [______________|v] //A
OrgUnit: [______________|v] //B
Worker Name: [________________] //C
A: (ComboViewer)
Bound to List<Organisation>
Not bound to FactoryWorker
B: (ComboViewer)
Bound to selectedOrganisation.orgUnits
Selected element bound to FactoryWorker.orgUnit
C: (Text)
Bound to FactoryWorker.name
FactoryWorker doesn't need a reference to Organisation as OrgUnit can
only have one Organisation as parent.
Most of the examples I have found don't deal with this sort of scenario.
They mostly have scenarios where the select of both A and B are bound to
the Model object.
How would I go about binding this scenario?
Cheers!
Ashley Cambrell
Re: [DataBinding] Cascading comboviewers [message #313499 is a reply to message #313420] Thu, 15 March 2007 11:14 Go to previous messageGo to next message
This is what we refer to as master detail. There's a snippet in the
examples project for doing this with a table and other widgets and the
concept should be the same. I've also written about this on my blog[1].
-brad
[1] http://fire-change-event.blogspot.com/search/label/master%20 detail
Re: [DataBinding] Cascading comboviewers [message #313504 is a reply to message #313499] Thu, 15 March 2007 16:19 Go to previous messageGo to next message
Doesn't that assume that the Organisation is the master and worker is
the detail? In this case it would be perfectly valid to have two sets
of cascading combos.
FactoryWorker Form
Worker Name: [________________] //A
Organisation: [______________|v] //B
OrgUnit: [______________|v] //C
Type of Health[______________|v] //D InsuranceType.insuranceCos
Insurance:
Insurance Co.:[______________|v] //E FactoryWork.insuranceCo
D: Public or Private
E: List of health insurance companies that are public (if selected) or
private.
Using master detail, does it boil down to this?
// 1. Observe changes in Organisation selection.
// 2. Observe the orgUnits property of the current selection.
// 3. Observe changes in orgUnits selection.
// 4. Bind the selectio of orgUnis to the orgUnit factoryWork object.
... repeat for insuranceType and insuranceCo.
Thanks Brad,
Ashley Cambrell
> -brad
Re: [DataBinding] Cascading comboviewers [message #313506 is a reply to message #313504] Thu, 15 March 2007 17:20 Go to previous messageGo to next message
> the detail?
I don't believe so.
Correct.
-brad
p.s. I have so much cold medicine in me I could get arrested so I might
not be thinking too clearly. If you still have issues work up a
standalone snippet and I'll take a look.
Re: [DataBinding] Cascading comboviewers [message #313518 is a reply to message #313506] Fri, 16 March 2007 08:39 Go to previous messageGo to next message
Hi Brad,
I'm stuck at step three.
I've created a test rcp app that has a structure similar to an
enterprise application (objects, a couple of services etc). I've added
the basic data binding to it. It's a contrived example, but it sets the
context nicely. It might be useful to others once it's completed.
Would you mind helping me fill in the gaps in
DatabindingViewer#initializeDataBinding?
http://users.tpg.com.au/cambrell/com.freakynamuh.databinding .test-20070316.zip
Hope you're feeling better.
Ashley
>> the detail?
> I don't believe so.
> Correct.
> -brad
Re: [DataBinding] Cascading comboviewers [message #313573 is a reply to message #313518] Mon, 19 March 2007 15:35 Go to previous message
Originally posted by: bokowski.ca.ibm.com
For legal reasons, we cannot easily download content that is not hosted at
eclipse.org. Would you be able to file a bug for this and attach your
example zip to the bug? (This would mean licensing your example code under
the EPL.)
Boris
"Ashley" <smithbb+eclipse-news@gmail.com> wrote in message
news:ete36o$e7u$1@utils.eclipse.org...
> Hi Brad,
> I've created a test rcp app that has a structure similar to an enterprise
> application (objects, a couple of services etc). I've added the basic data
> binding to it. It's a contrived example, but it sets the context nicely.
> Cheers,
> Ashley
>>> the detail?
>> I don't believe so.
>> Correct.
>> -brad
Previous Topic:VM constantly crashes with Eclipse 3.2.2 on Linux
Next Topic:Internal Web Browser
Current Time: Sun Oct 19 02:06:58 EDT 2025
Powered by FUDForum. Page generated in 0.32508 seconds
