Home » Eclipse Projects » Eclipse Platform » Crashing on Linux
Crashing on Linux [message #313269] Fri, 09 March 2007 19:13 Go to next message
--------------010402070208070609020207
Content-Type: text/plain; charset=us-ascii; format=flowed
hi -
I have been working on linux with 3.1 and no problems
Upgrading to 3.2.2, I am crashing very frequently
Here is the latest log after crash
Any clues?
thanks!
Anima.
name="hs_err_pid26563.log"
Content-Disposition: inline;
filename="hs_err_pid26563.log"
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00010206, pid=26563, tid=1073980576
# Java VM: Java HotSpot(TM) Client VM (1.5.0_05-b05 mixed mode)
# Problematic frame:
# C 0x00010206
--------------- T H R E A D ---------------
Current thread (0x0805b298): JavaThread "main" [_thread_in_Java, id=26563]
siginfo:si_signo=33700, si_errno=0, si_code=0
Registers:
EAX=0x00000004, EBX=0x47ff65f0, ECX=0x0000000e, EDX=0x00000000
ESP=0xbfff9070, EBP=0x47ff65f0, ESI=0xbfff92ec, EDI=0xbfff9308
EIP=0x00010206, CR2=0xffff0063, EFLAGS=0x0000002b
Top of Stack: (sp=0xbfff9070)
0xbfff9070: ffff027f ffff0063 ffffffff 4020cb9a
0xbfff9080: 02e80023 468f1a38 0000002b 00000000
0xbfff9090: e1008000 8000400e 5c81135c 3ffa8113
0xbfff90a0: 00000000 80000000 0000400f 00000000
0xbfff90b0: 3ffe8000 00000000 80000000 0000400f
0xbfff90c0: 00000000 00000000 00000000 80000000
0xbfff90d0: 00003fff 00000000 3fff8000 00000063
0xbfff90e0: 0063027f 02e80000 4020cb9a 00000023
Instructions: (pc=0x00010206)
0x000101f6:
[error occurred during error reporting, step 100, id 0xb]
Stack: [0xbfe00000,0xc0000000), sp=0xbfff9070, free space=2020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x00010206
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x08a18148 JavaThread "Worker-3" [_thread_blocked, id=26792]
0x08963ab0 JavaThread "Worker-2" [_thread_blocked, id=26583]
0x083336c0 JavaThread "Java indexing" daemon [_thread_blocked, id=26580]
0x083f4460 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=26577]
0x083f4b30 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=26576]
0x083f5488 JavaThread "State Data Manager" daemon [_thread_blocked, id=26575]
0x080c57a0 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=26569]
0x080c40d8 JavaThread "CompilerThread0" daemon [_thread_blocked, id=26568]
0x080c3258 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=26567]
0x080b86f0 JavaThread "Finalizer" daemon [_thread_blocked, id=26566]
0x080b7a78 JavaThread "Reference Handler" daemon [_thread_blocked, id=26565]
=>0x0805b298 JavaThread "main" [_thread_in_Java, id=26563]
Other Threads:
0x080b4e40 VMThread [id=26564]
0x080c6c30 WatcherThread [id=26570]
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0805a6b0/0x0805a6d8] Safepoint_lock - owner thread: 0x080b4e40
[0x0805a730/0x0805a758] Threads_lock - owner thread: 0x080b4e40
Heap
def new generation total 2880K, used 1947K [0x46720000, 0x46a40000, 0x47ad0000)
eden space 2560K, 76% used [0x46720000, 0x46906ca8, 0x469a0000)
from space 320K, 0% used [0x469a0000, 0x469a0000, 0x469f0000)
to space 320K, 0% used [0x469f0000, 0x469f0000, 0x46a40000)
tenured generation total 37824K, used 13435K [0x47ad0000, 0x49fc0000, 0x56720000)
the space 37824K, 35% used [0x47ad0000, 0x487eec80, 0x487eee00, 0x49fc0000)
compacting perm gen total 32256K, used 32129K [0x56720000, 0x586a0000, 0x5a720000)
the space 32256K, 99% used [0x56720000, 0x586805d8, 0x58680600, 0x586a0000)
No shared spaces configured.
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:02 1995547 /home/agupta/src/javaLinux1.5.0_05/bin/java
08056000-08058000 rw-p 0000e000 03:02 1995547 /home/agupta/src/javaLinux1.5.0_05/bin/java
08058000-092a0000 rwxp 00000000 00:00 0
40000000-40015000 r-xp 00000000 03:02 3908136 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:02 3908136 /lib/ld-2.3.2.so
40016000-40017000 rw-p 00000000 00:00 0
40017000-40018000 ---p 00000000 00:00 0
40018000-40019000 rwxp 00001000 00:00 0
40019000-4001f000 r-xp 00000000 03:02 1701508 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/native_threa ds/libhpi.so
4001f000-40020000 rw-p 00006000 03:02 1701508 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/native_threa ds/libhpi.so
40020000-40028000 rw-s 00000000 03:02 4416048 /tmp/hsperfdata_agupta/26563
40028000-4002a000 r--s 00000000 03:02 2077557 /home/agupta/src/javaLinux1.5.0_05/jre/lib/ext/dnsns.jar
4002a000-40034000 r-xp 00000000 03:02 719501 /lib/tls/libpthread-0.29.so
40034000-40035000 rw-p 0000a000 03:02 719501 /lib/tls/libpthread-0.29.so
40035000-40037000 rw-p 00000000 00:00 0
40037000-40039000 r-xp 00000000 03:02 3908147 /lib/libdl-2.3.2.so
40039000-4003a000 rw-p 00002000 03:02 3908147 /lib/libdl-2.3.2.so
4003a000-4003b000 rw-p 00000000 00:00 0
4003b000-4036a000 r-xp 00000000 03:02 703723 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/client/libjv m.so
4036a000-40387000 rw-p 0032f000 03:02 703723 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/client/libjv m.so
40387000-4079d000 rw-p 00000000 00:00 0
4079d000-407be000 r-xp 00000000 03:02 719499 /lib/tls/libm-2.3.2.so
407be000-407bf000 rw-p 00020000 03:02 719499 /lib/tls/libm-2.3.2.so
407bf000-407ca000 r-xp 00000000 03:02 981996 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libverify.so
407ca000-407cb000 rw-p 0000b000 03:02 981996 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libverify.so
407cb000-407d1000 r-xp 00000000 03:02 981992 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libnio.so
407d1000-407d2000 rw-p 00005000 03:02 981992 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libnio.so
407d2000-407e4000 r-xp 00000000 03:02 3908151 /lib/libnsl-2.3.2.so
407e4000-407e5000 rw-p 00011000 03:02 3908151 /lib/libnsl-2.3.2.so
407e5000-407e7000 rw-p 00000000 00:00 0
407e7000-407f2000 r-xp 00000000 03:02 3908157 /lib/libnss_files-2.3.2.so
407f2000-407f3000 rw-p 0000a000 03:02 3908157 /lib/libnss_files-2.3.2.so
407f3000-40814000 r-xp 00000000 03:02 981977 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libjava.so
40814000-40816000 rw-p 00020000 03:02 981977 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libjava.so
40816000-40829000 r-xp 00000000 03:02 981997 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libzip.so
40829000-4082b000 rw-p 00012000 03:02 981997 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libzip.so
4082b000-40894000 rw-p 00000000 00:00 0
40894000-4091b000 r--s 00000000 03:02 1161570 /home/agupta/src/javaLinux1.5.0_05/jre/lib/jsse.jar
4091b000-4092f000 r--s 00000000 03:02 1161569 /home/agupta/src/javaLinux1.5.0_05/jre/lib/jce.jar
4092f000-4116a000 r--s 00000000 03:02 1161451 /home/agupta/src/javaLinux1.5.0_05/jre/lib/charsets.jar
4116a000-41323000 rwxp 00001000 00:00 0
41323000-41324000 ---p 001ba000 00:00 0
41324000-413a3000 rwxp 001bb000 00:00 0
413a3000-413a6000 ---p 0023a000 00:00 0
413a6000-41423000 rwxp 0023d000 00:00 0
41423000-41426000 ---p 002ba000 00:00 0
41426000-414a3000 rwxp 002bd000 00:00 0
414a3000-416a3000 r--p 00000000 03:02 474216 /usr/lib/locale/locale-archive
416a3000-416a6000 ---p 00003000 00:00 0
416a6000-41723000 rwxp 00006000 00:00 0
41723000-41726000 ---p 00083000 00:00 0
41726000-417a3000 rwxp 00086000 00:00 0
417a3000-417a6000 ---p 00103000 00:00 0
417a6000-41823000 rwxp 00106000 00:00 0
41823000-41824000 ---p 00183000 00:00 0
41824000-418a3000 rwxp 00184000 00:00 0
418a3000-418ac000 r--s 00000000 03:02 2175914 /home/agupta/eclipse3.2/eclipse/startup.jar
418ac000-418f4000 r--s 00000000 03:02 2077555 /home/agupta/src/javaLinux1.5.0_05/jre/lib/ext/IngrianNAE.ja r
418f4000-419b8000 r--s 00000000 03:02 2077558 /home/agupta/src/javaLinux1.5.0_05/jre/lib/ext/localedata.ja r
419b8000-419de000 r--s 00000000 03:02 2077559 /home/agupta/src/javaLinux1.5.0_05/jre/lib/ext/sunjce_provid er.jar
419de000-41a09000 r--s 00000000 03:02 2077560 /home/agupta/src/javaLinux1.5.0_05/jre/lib/ext/sunpkcs11.jar
41a09000-41a12000 r--s 00000000 03:02 2175914 /home/agupta/eclipse3.2/eclipse/startup.jar
41a12000-41a15000 ---p 000a5000 00:00 0
41a15000-41a92000 rwxp 000a8000 00:00 0
41a92000-41b68000 r--s 00000000 03:02 2175899 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi_3.2 .2.R32x_v20070118.jar
41b68000-41b7c000 r-xp 00000000 03:02 981991 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libnet.so
41b7c000-41b7d000 rw-p 00013000 03:02 981991 /home/agupta/src/javaLinux1.5.0_05/jre/lib/i386/libnet.so
41b7d000-41b80000 ---p 00003000 00:00 0
41b80000-41bfd000 rwxp 00006000 00:00 0
41bfd000-41c00000 ---p 00083000 00:00 0
41c00000-41c7d000 rwxp 00086000 00:00 0
41c7d000-41c80000 ---p 00103000 00:00 0
41c80000-41cfd000 rwxp 00106000 00:00 0
41cfd000-41d11000 r--s 00000000 03:02 2175895 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. common_3.2.0.v20060603.jar
41d11000-41d28000 r--s 00000000 03:02 2175869 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c onfigurator_3.2.2.R32x_v20070111.jar
41d28000-41d3c000 r--s 00000000 03:02 2175861 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time_3.2.0.v20060603.jar
41d3c000-41d60000 r--s 00000000 03:02 2175858 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. registry_3.2.1.R32x_v20060814.jar
41d60000-41d62000 r--s 00000000 03:02 769220 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility.registry_3.2.1.R32x_v20060907/runtime_reg istry_compatibility.jar
41d62000-41d67000 r--s 00000000 03:02 2175883 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility.auth_3.2.0.v20060601.jar
41d67000-41d7e000 r--s 00000000 03:02 2175859 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.equinox. preferences_3.2.1.R32x_v20060717.jar
41d7e000-41d91000 r--s 00000000 03:02 2175837 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.job s_3.2.0.v20060603.jar
41d91000-41da7000 r--s 00000000 03:02 2175871 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.run time.compatibility_3.1.100.v20060603.jar
41da7000-41f44000 r--s 00000000 03:02 2175822 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.ide_3 .2.1.M20060915-1030.jar
41f44000-41f45000 r--s 00000000 03:02 1979177 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench.compatibility_3.2.0.I20060605-1400/compatibility.jar
41f45000-41f48000 r--s 00000000 03:02 2175844 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.swt_3.2. 2.v3236b.jar
41f48000-41f67000 r--s 00000000 03:02 2175855 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui_3.2.1 .M20061108.jar
41f67000-41f7e000 r--s 00000000 03:02 2175863 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.com mands_3.2.0.I20060605-1400.jar
41f7e000-41fc9000 r-xp 00000000 03:02 3565517 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-pi-gtk-3236.so
41fc9000-41fcb000 rw-p 0004a000 03:02 3565517 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-pi-gtk-3236.so
41fcb000-41fd1000 r--s 00000000 03:02 588870 /usr/lib/gconv/gconv-modules.cache
41fd1000-41fd2000 r-xp 00000000 03:02 654139 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
41fd2000-41fd3000 rw-p 00000000 03:02 654139 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
41fd3000-41fdb000 r-xp 00000000 03:02 997638 /usr/lib/gtk-2.0/2.2.0/engines/libpixmap.so
41fdb000-41fdc000 rw-p 00007000 03:02 997638 /usr/lib/gtk-2.0/2.2.0/engines/libpixmap.so
41fdc000-41fdd000 r-xp 00000000 03:02 588814 /usr/lib/gconv/ISO8859-1.so
41fdd000-41fde000 rw-p 00001000 03:02 588814 /usr/lib/gconv/ISO8859-1.so
41fde000-41fe2000 r-xp 00000000 03:02 359781 /usr/lib/libgthread-2.0.so.0.200.1
41fe2000-41fe3000 rw-p 00003000 03:02 359781 /usr/lib/libgthread-2.0.so.0.200.1
41fe3000-41fe7000 r-xp 00000000 03:02 2338417 /usr/X11R6/lib/libXtst.so.6.1
41fe7000-41fe8000 rw-p 00004000 03:02 2338417 /usr/X11R6/lib/libXtst.so.6.1
41fe8000-41ffa000 r-xp 00000000 03:02 359980 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
41ffa000-41ffb000 rw-p 00011000 03:02 359980 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
41ffb000-41ffe000 r-xp 00000000 03:02 359777 /usr/lib/libgmodule-2.0.so.0.200.1
41ffe000-41fff000 rw-p 00002000 03:02 359777 /usr/lib/libgmodule-2.0.so.0.200.1
41fff000-42000000 r--p 00000000 00:00 0
42000000-4212e000 r-xp 00000000 03:02 719497 /lib/tls/libc-2.3.2.so
4212e000-42131000 rw-p 0012e000 03:02 719497 /lib/tls/libc-2.3.2.so
42131000-42133000 rw-p 00000000 00:00 0
42133000-4471d000 r--s 00000000 03:02 1161577 /home/agupta/src/javaLinux1.5.0_05/jre/lib/rt.jar
4471d000-4671d000 rwxp 00028000 00:00 0
4671d000-4671f000 r-xp 00000000 03:02 3041542 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4671f000-46720000 rw-p 00001000 03:02 3041542 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
46720000-5a720000 rwxp 0233b000 00:00 0
5a720000-5aa20000 r--s 00000000 03:02 2175873 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench_3.2.2.M20070119-0800.jar
5aa20000-5aaeb000 r--s 00000000 03:02 2175819 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface_3. 2.2.M20061214-1200.jar
5aaeb000-5acaa000 r--s 00000000 03:02 2175878 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.swt.gtk. linux.x86_3.2.2.v3236.jar
5acaa000-5aef3000 r-xp 00000000 03:02 359984 /usr/lib/libgtk-x11-2.0.so.0.200.1
5aef3000-5aefc000 rw-p 00248000 03:02 359984 /usr/lib/libgtk-x11-2.0.so.0.200.1
5aefc000-5aefe000 rw-p 00000000 00:00 0
5aefe000-5af67000 r-xp 00000000 03:02 359978 /usr/lib/libgdk-x11-2.0.so.0.200.1
5af67000-5af6c000 rw-p 00069000 03:02 359978 /usr/lib/libgdk-x11-2.0.so.0.200.1
5af6c000-5af8c000 r-xp 00000000 03:02 359976 /usr/lib/libpangoxft-1.0.so.0.200.1
5af8c000-5af8d000 rw-p 0001f000 03:02 359976 /usr/lib/libpangoxft-1.0.so.0.200.1
5af8d000-5af99000 r-xp 00000000 03:02 359974 /usr/lib/libpangox-1.0.so.0.200.1
5af99000-5af9a000 rw-p 0000b000 03:02 359974 /usr/lib/libpangox-1.0.so.0.200.1
5af9a000-5afc1000 r-xp 00000000 03:02 359970 /usr/lib/libpango-1.0.so.0.200.1
5afc1000-5afcd000 rw-p 00026000 03:02 359970 /usr/lib/libpango-1.0.so.0.200.1
5afcd000-5afe4000 r-xp 00000000 03:02 359946 /usr/lib/libatk-1.0.so.0.200.0
5afe4000-5afe6000 rw-p 00016000 03:02 359946 /usr/lib/libatk-1.0.so.0.200.0
5afe6000-5b019000 r-xp 00000000 03:02 359779 /usr/lib/libgobject-2.0.so.0.200.1
5b019000-5b01b000 rw-p 00032000 03:02 359779 /usr/lib/libgobject-2.0.so.0.200.1
5b01b000-5b084000 r-xp 00000000 03:02 359775 /usr/lib/libglib-2.0.so.0.200.1
5b084000-5b085000 rw-p 00069000 03:02 359775 /usr/lib/libglib-2.0.so.0.200.1
5b085000-5b092000 r-xp 00000000 03:02 2338393 /usr/X11R6/lib/libXext.so.6.4
5b092000-5b093000 rw-p 0000c000 03:02 2338393 /usr/X11R6/lib/libXext.so.6.4
5b093000-5b16f000 r-xp 00000000 03:02 2338383 /usr/X11R6/lib/libX11.so.6.2
5b16f000-5b172000 rw-p 000db000 03:02 2338383 /usr/X11R6/lib/libX11.so.6.2
5b172000-5b175000 r-xp 00000000 03:02 2338411 /usr/X11R6/lib/libXrandr.so.2.0
5b175000-5b176000 rw-p 00002000 03:02 2338411 /usr/X11R6/lib/libXrandr.so.2.0
5b176000-5b17d000 r-xp 00000000 03:02 2338401 /usr/X11R6/lib/libXi.so.6.0
5b17d000-5b17e000 rw-p 00006000 03:02 2338401 /usr/X11R6/lib/libXi.so.6.0
5b17e000-5b18f000 r-xp 00000000 03:02 2338399 /usr/X11R6/lib/libXft.so.2.1
5b18f000-5b190000 rw-p 00010000 03:02 2338399 /usr/X11R6/lib/libXft.so.2.1
5b190000-5b197000 r-xp 00000000 03:02 2338413 /usr/X11R6/lib/libXrender.so.1.2
5b197000-5b198000 rw-p 00006000 03:02 2338413 /usr/X11R6/lib/libXrender.so.1.2
5b198000-5b1b9000 r-xp 00000000 03:02 359893 /usr/lib/libfontconfig.so.1.0
5b1b9000-5b1bc000 rw-p 00021000 03:02 359893 /usr/lib/libfontconfig.so.1.0
5b1bc000-5b1bd000 rw-p 00000000 00:00 0
5b1bd000-5b209000 r-xp 00000000 03:02 359889 /usr/lib/libfreetype.so.6.3.2
5b209000-5b20d000 rw-p 0004c000 03:02 359889 /usr/lib/libfreetype.so.6.3.2
5b20d000-5b20e000 rw-p 00000000 00:00 0
5b20e000-5b22c000 r-xp 00000000 03:02 359765 /usr/lib/libexpat.so.0.4.0
5b22c000-5b22e000 rw-p 0001e000 03:02 359765 /usr/lib/libexpat.so.0.4.0
5b22e000-5b254000 r-xp 00000000 03:02 3565518 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gtk-3236.so
5b254000-5b256000 rw-p 00025000 03:02 3565518 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gtk-3236.so
5b256000-5b257000 rw-p 00000000 00:00 0
5b257000-5b269000 r--p 00000000 03:02 4676870 /usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
5b269000-5b26a000 r--s 00000000 03:02 2175882 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.boo t_3.1.100.v20060603.jar
5b26a000-5b272000 r-xp 00000000 03:02 2338391 /usr/X11R6/lib/libXcursor.so.1.0
5b272000-5b273000 rw-p 00007000 03:02 2338391 /usr/X11R6/lib/libXcursor.so.1.0
5b273000-5b285000 r--p 00000000 03:02 4676872 /usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
5b285000-5b289000 r-xp 00000000 03:02 2387502 /usr/lib/gtk-2.0/2.2.0/loaders/libpixbufloader-png.so
5b289000-5b28a000 rw-p 00003000 03:02 2387502 /usr/lib/gtk-2.0/2.2.0/loaders/libpixbufloader-png.so
5b28a000-5b293000 r--s 00000000 03:02 2175884 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil esystem_1.0.0.v20060603.jar
5b293000-5b297000 r--s 00000000 03:02 2175898 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil esystem.linux.x86_1.0.0.v20060603.jar
5b297000-5b299000 r-xp 00000000 03:02 2437396 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/104/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
5b299000-5b29a000 rw-p 00001000 03:02 2437396 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/104/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
5b29a000-5b29d000 r--s 00000000 03:02 2175891 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.rcp_3.2. 0.v20060605.jar
5b29d000-5b2bf000 r-xp 00000000 03:02 359899 /usr/lib/libpng12.so.0.1.2.2
5b2bf000-5b2c0000 rw-p 00022000 03:02 359899 /usr/lib/libpng12.so.0.1.2.2
5b2c0000-5b2cc000 r-xp 00000000 03:02 359809 /usr/lib/libz.so.1.1.4
5b2cc000-5b2ce000 rw-p 0000b000 03:02 359809 /usr/lib/libz.so.1.1.4
5b2ce000-5b370000 r--s 00000000 03:02 2175890 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.res ources_3.2.2.R32x_v20061218.jar
5b370000-5b38d000 r--s 00000000 03:02 2175864 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.res ources.compatibility_3.2.0.v20060603.jar
5b38d000-5b3a0000 r--s 00000000 03:02 2175839 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.con tenttype_3.2.0.v20060603.jar
5b3a0000-5b420000 rwxp 0002a000 00:00 0
5b420000-5b431000 r--s 00000000 03:02 2175880 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.exp ressions_3.2.2.r322_v20070109a.jar
5b431000-5b45c000 r--s 00000000 03:02 2175856 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.brows er_3.2.0.v20060602.jar
5b45c000-5b4a5000 r--s 00000000 03:02 2175862 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.cheat sheets_3.2.1.R321_v20060720.jar
5b4a5000-5b4a8000 ---p 00009000 00:00 0
5b4a8000-5b525000 rwxp 0000c000 00:00 0
5b525000-5b546000 r--s 00000000 03:02 2175824 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.exter naltools_3.1.101.r321_v20060802.jar
5b546000-5b5b7000 r--s 00000000 03:02 2175827 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.edito rs_3.2.1.r321_v20060721.jar
5b5b7000-5b622000 r--s 00000000 03:02 2175828 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.workb ench.texteditor_3.2.0.v20060605-1400.jar
5b622000-5b691000 r--s 00000000 03:02 2175833 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.search_3 .2.1.r321_v20060726.jar
5b691000-5b799000 r--s 00000000 03:02 2175836 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ant.ui_3 .2.1.r321_v20060828.jar
5b799000-5b90c000 r--s 00000000 03:02 2175885 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ui_3.2.2.M20061121.jar
5b90c000-5ba25000 r--s 00000000 03:02 2175900 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g.ui_3.2.2.r322_v20061205.jar
5ba25000-5bb2e000 r--s 00000000 03:02 2175901 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.ui_ 3.2.1.M200608151725.jar
5bb2e000-5bcfe000 r--s 00000000 03:02 2175902 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.debug.ui _3.2.2.r322_v20070202.jar
5bcfe000-5c4e1000 r--s 00000000 03:02 2175904 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.ui_3 .2.2.r322_v20070124.jar
5c4e1000-5c504000 rw-p 00000000 00:00 0
5c504000-5c523000 r--s 00000000 03:02 2175865 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help_3.2 .2.R322_v20061213.jar
5c523000-5c52d000 r--s 00000000 03:02 2175835 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt_3.2. 1.r321_v20060823.jar
5c52d000-5c53d000 r--s 00000000 03:02 2175876 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde_3.2. 1.v20060810-0800.jar
5c53d000-5c85f000 r--s 00000000 03:02 2175820 /home/agupta/eclipse3.2/eclipse/plugins/com.ibm.icu_3.4.5.20 061213.jar
5c85f000-5c865000 r-xp 00000000 03:02 3565519 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-atk-gtk-3236.so
5c865000-5c866000 rw-p 00005000 03:02 3565519 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-atk-gtk-3236.so
5c866000-5c8a5000 r-xp 00000000 03:02 3565520 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libcairo-swt.so
5c8a5000-5c8a6000 rw-p 0003f000 03:02 3565520 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libcairo-swt.so
5c8a6000-5c8af000 r-xp 00000000 03:02 3565521 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-cairo-gtk-3236.so
5c8af000-5c8b0000 rw-p 00009000 03:02 3565521 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-cairo-gtk-3236.so
5c8b0000-5c8c1000 r--s 00000000 03:02 2175849 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.views _3.2.1.M20060906-0800.jar
5c8c1000-5c982000 r--s 00000000 03:02 2175881 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface.te xt_3.2.2.r322_v20070104.jar
5c982000-5c9b8000 r--s 00000000 03:02 2175853 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.text_3.2 .0.v20060605-1400.jar
5c9b8000-5cd8d000 r--s 00000000 03:02 2175887 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.core _3.2.3.v_686_R32x.jar
5cd8d000-5cd90000 ---p 00003000 00:00 0
5cd90000-5ce0d000 rwxp 00006000 00:00 0
5ce0d000-5ce24000 r--s 00000000 03:02 2175842 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.fil ebuffers_3.2.1.r321_v20060721.jar
5ce24000-5ce7d000 r--s 00000000 03:02 2175825 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cor e_3.2.2.M20061114.jar
5ce7d000-5ceb9000 r--s 00000000 03:02 2175830 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.debug.co re_3.2.1..v20060823.jar
5ceb9000-5d202000 r--s 00000000 03:02 2175843 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.ui_3 .2.1.v20060816-0800.jar
5d202000-5d209000 r--s 00000000 03:02 2175888 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.s cheduler_3.2.2.R32x_v20061214.jar
5d209000-5d298000 r--s 00000000 03:02 2175826 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c ore_3.2.3.R32x_v20070118.jar
5d298000-5d29a000 r--s 00000000 03:02 2175905 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.c ore.linux_3.2.0.v20060605.jar
5d29a000-5d35c000 r--s 00000000 03:02 2175850 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.core _3.2.1.v20060915-0800.jar
5d35c000-5d396000 r--s 00000000 03:02 2175857 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.laun ching_3.2.2.r322_v20061114.jar
5d396000-5d3d1000 r--s 00000000 03:02 2175831 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.forms _3.2.0.v20060602.jar
5d3d1000-5d3d8000 r--s 00000000 03:02 2175893 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.core.var iables_3.1.100.v20060605.jar
5d3d8000-5d458000 rwxp 00024000 00:00 0
5d458000-5d4cc000 r--s 00000000 03:02 2175834 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.compare_ 3.2.1.M20060711.jar
5d4cc000-5d4de000 r--p 00000000 03:02 4676874 /usr/X11R6/lib/X11/fonts/Type1/l048033t.pfa
5d4de000-5d4f0000 r--p 00000000 03:02 4676876 /usr/X11R6/lib/X11/fonts/Type1/l048036t.pfa
5d4f0000-5d503000 r--p 00000000 03:02 4676862 /usr/X11R6/lib/X11/fonts/Type1/l047013t.pfa
5d503000-5d510000 r--s 00000000 03:02 1292810 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g_3.2.2.r322_v20070130/jdi.jar
5d510000-5d512000 r-xp 00000000 03:02 3368770 /usr/local/mozilla/libplds4.so
5d512000-5d513000 rw-p 00001000 03:02 3368770 /usr/local/mozilla/libplds4.so
5d513000-5d515000 r-xp 00000000 03:02 588858 /usr/lib/gconv/UTF-16.so
5d515000-5d516000 rw-p 00001000 03:02 588858 /usr/lib/gconv/UTF-16.so
5d517000-5d52b000 r--p 00000000 03:02 4676866 /usr/X11R6/lib/X11/fonts/Type1/l047033t.pfa
5d52b000-5d53e000 r-xp 00000000 03:02 3565523 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla-gcc3-gtk-3236.so
5d53e000-5d53f000 rw-p 00012000 03:02 3565523 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla-gcc3-gtk-3236.so
5d53f000-5d59c000 r--s 00000000 03:02 2862610 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.juni t_3.2.1.r321_v20060810/junitsupport.jar
5d59c000-5d5b3000 r--s 00000000 03:02 2175886 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ant.core _3.1.100.v20060531.jar
5d5b3000-5d5f7000 r--s 00000000 03:02 2600964 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.buil d_3.2.1.r321_v20060823/pdebuild.jar
5d5f7000-5d5fb000 r-xp 00000000 03:02 3368769 /usr/local/mozilla/libplc4.so
5d5fb000-5d5fc000 rw-p 00003000 03:02 3368769 /usr/local/mozilla/libplc4.so
5d5fc000-5d5ff000 r-xp 00000000 03:02 3368760 /usr/local/mozilla/libgtkxtbin.so
5d5ff000-5d600000 rw-p 00003000 03:02 3368760 /usr/local/mozilla/libgtkxtbin.so
5d600000-5d60c000 rw-p 000c1000 00:00 0
5d60c000-5d700000 ---p 000c9000 00:00 0
5d700000-5d7b8000 r--s 00000000 03:02 1292811 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.debu g_3.2.2.r322_v20070130/jdimodel.jar
5d7b8000-5d88c000 r-xp 00000000 03:02 3368778 /usr/local/mozilla/libxpcom.so
5d88c000-5d893000 rw-p 000d3000 03:02 3368778 /usr/local/mozilla/libxpcom.so
5d893000-5d8c3000 r-xp 00000000 03:02 3368766 /usr/local/mozilla/libnspr4.so
5d8c3000-5d8c5000 rw-p 00030000 03:02 3368766 /usr/local/mozilla/libnspr4.so
5d8c5000-5d8c6000 rw-p 00000000 00:00 0
5d8c6000-5d8ce000 r-xp 00000000 03:02 3565526 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla14-profile-gcc3-gtk-3236.s o
5d8ce000-5d8cf000 rw-p 00008000 03:02 3565526 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-mozilla14-profile-gcc3-gtk-3236.s o
5d8cf000-5d8d7000 r-xp 00000000 03:02 1358088 /usr/local/mozilla/components/libsystem-pref.so
5d8d7000-5d8d8000 rw-p 00008000 03:02 1358088 /usr/local/mozilla/components/libsystem-pref.so
5d8d9000-5d982000 r-xp 00000000 03:02 359847 /usr/lib/libstdc++.so.5.0.3
5d982000-5d987000 rw-p 000a9000 03:02 359847 /usr/lib/libstdc++.so.5.0.3
5d987000-5d98c000 rw-p 00000000 00:00 0
5d98c000-5d993000 r-xp 00000000 03:02 3908190 /lib/libgcc_s-3.2.2-20030225.so.1
5d993000-5d994000 rw-p 00007000 03:02 3908190 /lib/libgcc_s-3.2.2-20030225.so.1
5d994000-5d9b6000 r-xp 00000000 03:02 3368758 /usr/local/mozilla/libgkgfx.so
5d9b6000-5d9b8000 rw-p 00021000 03:02 3368758 /usr/local/mozilla/libgkgfx.so
5d9b8000-5da26000 r-xp 00000000 03:02 3368763 /usr/local/mozilla/libmozjs.so
5da26000-5da2a000 rw-p 0006e000 03:02 3368763 /usr/local/mozilla/libmozjs.so
5da2a000-5da53000 r-xp 00000000 03:02 1358018 /usr/local/mozilla/components/libembedcomponents.so
5da53000-5da55000 rw-p 00029000 03:02 1358018 /usr/local/mozilla/components/libembedcomponents.so
5da55000-5da65000 r-xp 00000000 03:02 1358097 /usr/local/mozilla/components/libtypeaheadfind.so
5da65000-5da66000 rw-p 00010000 03:02 1358097 /usr/local/mozilla/components/libtypeaheadfind.so
5da66000-5da78000 r-xp 00000000 03:02 1357952 /usr/local/mozilla/components/libpref.so
5da78000-5da79000 rw-p 00012000 03:02 1357952 /usr/local/mozilla/components/libpref.so
5da79000-5da84000 r-xp 00000000 03:02 3368764 /usr/local/mozilla/libmozz.so
5da84000-5da86000 rw-p 0000a000 03:02 3368764 /usr/local/mozilla/libmozz.so
5da86000-5db3e000 r-xp 00000000 03:02 1357946 /usr/local/mozilla/components/libnecko.so
5db3e000-5db45000 rw-p 000b7000 03:02 1357946 /usr/local/mozilla/components/libnecko.so
5db45000-5df37000 r-xp 00000000 03:02 1357997 /usr/local/mozilla/components/libgklayout.so
5df37000-5df6e000 rw-p 003f1000 03:02 1357997 /usr/local/mozilla/components/libgklayout.so
5df6e000-5df74000 rw-p 00000000 00:00 0
5df74000-5df88000 r-xp 00000000 03:02 1357954 /usr/local/mozilla/components/libcaps.so
5df88000-5df89000 rw-p 00014000 03:02 1357954 /usr/local/mozilla/components/libcaps.so
5df89000-5dfc7000 r-xp 00000000 03:02 1357912 /usr/local/mozilla/components/libxpconnect.so
5dfc7000-5dfcb000 rw-p 0003d000 03:02 1357912 /usr/local/mozilla/components/libxpconnect.so
5dfcb000-5dfcc000 ---p 00000000 00:00 0
5dfcc000-5e7cb000 rwxp 00001000 00:00 0
5e7cb000-5e803000 r-xp 00000000 03:02 1357922 /usr/local/mozilla/components/libi18n.so
5e803000-5e806000 rw-p 00038000 03:02 1357922 /usr/local/mozilla/components/libi18n.so
5e806000-5e82e000 r-xp 00000000 03:02 1357956 /usr/local/mozilla/components/librdf.so
5e82e000-5e830000 rw-p 00027000 03:02 1357956 /usr/local/mozilla/components/librdf.so
5e830000-5e85a000 r-xp 00000000 03:02 1357966 /usr/local/mozilla/components/libimglib2.so
5e85a000-5e85c000 rw-p 00029000 03:02 1357966 /usr/local/mozilla/components/libimglib2.so
5e85c000-5e86d000 r-xp 00000000 03:02 1358069 /usr/local/mozilla/components/libjsd.so
5e86d000-5e86e000 rw-p 00010000 03:02 1358069 /usr/local/mozilla/components/libjsd.so
5e86e000-5e87f000 r-xp 00000000 03:02 1358020 /usr/local/mozilla/components/libwebbrwsr.so
5e87f000-5e880000 rw-p 00011000 03:02 1358020 /usr/local/mozilla/components/libwebbrwsr.so
5e881000-5e8cf000 r-xp 00000000 03:02 2338415 /usr/X11R6/lib/libXt.so.6.0
5e8cf000-5e8d3000 rw-p 0004d000 03:02 2338415 /usr/X11R6/lib/libXt.so.6.0
5e8d3000-5e8db000 r-xp 00000000 03:02 2338381 /usr/X11R6/lib/libSM.so.6.0
5e8db000-5e8dc000 rw-p 00007000 03:02 2338381 /usr/X11R6/lib/libSM.so.6.0
5e8dc000-5e8f0000 r-xp 00000000 03:02 2338377 /usr/X11R6/lib/libICE.so.6.3
5e8f0000-5e8f1000 rw-p 00013000 03:02 2338377 /usr/X11R6/lib/libICE.so.6.3
5e8f1000-5e8f3000 rw-p 00000000 00:00 0
5e8f3000-5e924000 r-xp 00000000 03:02 1357985 /usr/local/mozilla/components/libwidget_gtk2.so
5e924000-5e928000 rw-p 00030000 03:02 1357985 /usr/local/mozilla/components/libwidget_gtk2.so
5e928000-5e92b000 r-xp 00000000 03:02 3908155 /lib/libnss_dns-2.3.2.so
5e92b000-5e92c000 rw-p 00003000 03:02 3908155 /lib/libnss_dns-2.3.2.so
5e92c000-5e93b000 r-xp 00000000 03:02 3908167 /lib/libresolv-2.3.2.so
5e93b000-5e93c000 rw-p 0000f000 03:02 3908167 /lib/libresolv-2.3.2.so
5e93c000-5e93e000 rw-p 00000000 00:00 0
5e93e000-5e971000 r-xp 00000000 03:02 359986 /usr/lib/libgconf-2.so.4.1.0
5e971000-5e974000 rw-p 00033000 03:02 359986 /usr/lib/libgconf-2.so.4.1.0
5e974000-5e9ad000 r-xp 00000000 03:02 359962 /usr/lib/libORBit-2.so.0.0.0
5e9ad000-5e9b6000 rw-p 00038000 03:02 359962 /usr/lib/libORBit-2.so.0.0.0
5e9b6000-5e9bd000 r-xp 00000000 03:02 359960 /usr/lib/liblinc.so.1.0.0
5e9bd000-5e9be000 rw-p 00006000 03:02 359960 /usr/lib/liblinc.so.1.0.0
5e9be000-5e9c5000 r-xp 00000000 03:02 359792 /usr/lib/libpopt.so.0.0.0
5e9c5000-5e9c6000 rw-p 00006000 03:02 359792 /usr/lib/libpopt.so.0.0.0
5e9c6000-5ea30000 r-xp 00000000 03:02 1357964 /usr/local/mozilla/components/libgfx_gtk.so
5ea30000-5ea36000 rw-p 00069000 03:02 1357964 /usr/local/mozilla/components/libgfx_gtk.so
5ea36000-5ea3f000 rw-p 00000000 00:00 0
5ea3f000-5ea46000 r-xp 00000000 03:02 1358041 /usr/local/mozilla/components/libpipboot.so
5ea46000-5ea47000 rw-p 00007000 03:02 1358041 /usr/local/mozilla/components/libpipboot.so
5ea47000-5ea4c000 r-xp 00000000 03:02 3549077 /usr/local/mozilla/plugins/libnullplugin.so
5ea4c000-5ea4d000 rw-p 00004000 03:02 3549077 /usr/local/mozilla/plugins/libnullplugin.so
5ea4d000-5ea50000 r-xp 00000000 03:02 3565528 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gnome-gtk-3236.so
5ea50000-5ea51000 rw-p 00002000 03:02 3565528 /home/agupta/eclipse3.2/eclipse/configuration/org.eclipse.os gi/bundles/80/1/.cp/libswt-gnome-gtk-3236.so
5ea52000-5ea59000 r-xp 00000000 03:02 2338407 /usr/X11R6/lib/libXp.so.6.2
5ea59000-5ea5a000 rw-p 00006000 03:02 2338407 /usr/X11R6/lib/libXp.so.6.2
5ea5a000-5eab8000 r-xp 00000000 03:02 1358001 /usr/local/mozilla/components/libdocshell.so
5eab8000-5eabb000 rw-p 0005e000 03:02 1358001 /usr/local/mozilla/components/libdocshell.so
5eabb000-5ead6000 r-xp 00000000 03:02 3368777 /usr/local/mozilla/libxpcom_compat.so
5ead6000-5ead7000 rw-p 0001b000 03:02 3368777 /usr/local/mozilla/libxpcom_compat.so
5ead7000-5eb42000 r-xp 00000000 03:02 1358066 /usr/local/mozilla/components/libappcomps.so
5eb42000-5eb46000 rw-p 0006a000 03:02 1358066 /usr/local/mozilla/components/libappcomps.so
5eb46000-5eb93000 r-xp 00000000 03:02 1357983 /usr/local/mozilla/components/libjsdom.so
5eb93000-5eb99000 rw-p 0004c000 03:02 1357983 /usr/local/mozilla/components/libjsdom.so
5eb99000-5eb9a000 rw-p 00000000 00:00 0
5eb9a000-5ebb1000 r-xp 00000000 03:02 3368761 /usr/local/mozilla/libjsj.so
5ebb1000-5ebb3000 rw-p 00017000 03:02 3368761 /usr/local/mozilla/libjsj.so
5ebb3000-5ebca000 r-xp 00000000 03:02 1357926 /usr/local/mozilla/components/liboji.so
5ebca000-5ebcb000 rw-p 00017000 03:02 1357926 /usr/local/mozilla/components/liboji.so
5ebcb000-5ebfa000 r-xp 00000000 03:02 1357968 /usr/local/mozilla/components/libgkplugin.so
5ebfa000-5ebfc000 rw-p 0002e000 03:02 1357968 /usr/local/mozilla/components/libgkplugin.so
5ebfc000-5ebfd000 ---p 00000000 00:00 0
5ebfd000-5f3fc000 rwxp 00001000 00:00 0
5f3fc000-5f40f000 r--s 00000000 03:02 3124244 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.intro .universal_3.2.1.R321_v20060905/universal.jar
5f40f000-5f446000 r-xp 00000000 03:02 359988 /usr/lib/libgnomevfs-2.so.0.0.0
5f446000-5f448000 rw-p 00036000 03:02 359988 /usr/lib/libgnomevfs-2.so.0.0.0
5f448000-5f45b000 r-xp 00000000 03:02 359992 /usr/lib/libgnome-2.so.0.200.0
5f45b000-5f45c000 rw-p 00013000 03:02 359992 /usr/lib/libgnome-2.so.0.200.0
5f45c000-5f4e4000 r-xp 00000000 03:02 360002 /usr/lib/libgnomeui-2.so.0.200.0
5f4e4000-5f4e7000 rw-p 00088000 03:02 360002 /usr/lib/libgnomeui-2.so.0.200.0
5f4e7000-5f4f8000 r-xp 00000000 03:02 359966 /usr/lib/libbonobo-activation.so.4.0.0
5f4f8000-5f4fa000 rw-p 00011000 03:02 359966 /usr/lib/libbonobo-activation.so.4.0.0
5f4fa000-5f5d9000 r-xp 00000000 03:02 359902 /usr/lib/libxml2.so.2.5.4
5f5d9000-5f5e4000 rw-p 000de000 03:02 359902 /usr/lib/libxml2.so.2.5.4
5f5e4000-5f5e5000 rw-p 00000000 00:00 0
5f5e5000-5f617000 r-xp 00000000 03:02 3908200 /lib/libssl.so.0.9.7a
5f617000-5f61a000 rw-p 00032000 03:02 3908200 /lib/libssl.so.0.9.7a
5f61a000-5f6f6000 r-xp 00000000 03:02 3908199 /lib/libcrypto.so.0.9.7a
5f6f6000-5f708000 rw-p 000db000 03:02 3908199 /lib/libcrypto.so.0.9.7a
5f708000-5f70b000 rw-p 00000000 00:00 0
5f70b000-5f711000 r-xp 00000000 03:02 3908169 /lib/librt-2.3.2.so
5f711000-5f713000 rw-p 00005000 03:02 3908169 /lib/librt-2.3.2.so
5f713000-5f71d000 rw-p 00000000 00:00 0
5f71d000-5f76b000 r-xp 00000000 03:02 359968 /usr/lib/libbonobo-2.so.0.0.0
5f76b000-5f774000 rw-p 0004e000 03:02 359968 /usr/lib/libbonobo-2.so.0.0.0
5f774000-5f77b000 r-xp 00000000 03:02 359950 /usr/lib/libesd.so.0.2.28
5f77b000-5f77c000 rw-p 00006000 03:02 359950 /usr/lib/libesd.so.0.2.28
5f77c000-5f79e000 r-xp 00000000 03:02 359948 /usr/lib/libaudiofile.so.0.0.2
5f79e000-5f7a1000 rw-p 00021000 03:02 359948 /usr/lib/libaudiofile.so.0.0.2
5f7a1000-5f800000 r-xp 00000000 03:02 360000 /usr/lib/libbonoboui-2.so.0.0.0
5f800000-5f803000 rw-p 0005f000 03:02 360000 /usr/lib/libbonoboui-2.so.0.0.0
5f803000-5f82f000 r-xp 00000000 03:02 359994 /usr/lib/libgnomecanvas-2.so.0.200.0
5f82f000-5f830000 rw-p 0002c000 03:02 359994 /usr/lib/libgnomecanvas-2.so.0.200.0
5f830000-5f845000 r-xp 00000000 03:02 359956 /usr/lib/libart_lgpl_2.so.2.3.11
5f845000-5f846000 rw-p 00015000 03:02 359956 /usr/lib/libart_lgpl_2.so.2.3.11
5f846000-5f867000 r-xp 00000000 03:02 359972 /usr/lib/libpangoft2-1.0.so.0.200.1
5f867000-5f868000 rw-p 00021000 03:02 359972 /usr/lib/libpangoft2-1.0.so.0.200.1
5f868000-5f885000 r-xp 00000000 03:02 359895 /usr/lib/libjpeg.so.62.0.0
5f885000-5f886000 rw-p 0001d000 03:02 359895 /usr/lib/libjpeg.so.62.0.0
5f886000-5f898000 r-xp 00000000 03:02 1177365 /usr/kerberos/lib/libgssapi_krb5.so.2.2
5f898000-5f899000 rw-p 00011000 03:02 1177365 /usr/kerberos/lib/libgssapi_krb5.so.2.2
5f899000-5f8f5000 r-xp 00000000 03:02 1177379 /usr/kerberos/lib/libkrb5.so.3.1
5f8f5000-5f8f7000 rw-p 0005c000 03:02 1177379 /usr/kerberos/lib/libkrb5.so.3.1
5f8f7000-5f906000 r-xp 00000000 03:02 1177369 /usr/kerberos/lib/libk5crypto.so.3.0
5f906000-5f907000 rw-p 0000f000 03:02 1177369 /usr/kerberos/lib/libk5crypto.so.3.0
5f907000-5f908000 r-xp 00000000 03:02 1177359 /usr/kerberos/lib/libcom_err.so.3.0
5f908000-5f909000 rw-p 00001000 03:02 1177359 /usr/kerberos/lib/libcom_err.so.3.0
5f909000-5f90d000 r-xp 00000000 03:02 359964 /usr/lib/libORBitCosNaming-2.so.0.0.0
5f90d000-5f90e000 rw-p 00004000 03:02 359964 /usr/lib/libORBitCosNaming-2.so.0.0.0
5f90e000-5f958000 r--s 00000000 03:02 2175823 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.intro _3.2.2.R322_v20061214.jar
5f958000-5f97b000 r--s 00000000 03:02 2175848 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.conso le_3.1.100.v20060605.jar
5f97b000-5f99d000 r--s 00000000 03:02 2175896 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.runt ime_3.2.0.v20060605.jar
5f99d000-5fa07000 r--s 00000000 03:02 2175821 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ltk.ui.r efactoring_3.2.2.r322_v20070124.jar
5fa07000-5fa4c000 r--s 00000000 03:02 2175829 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.bas e_3.2.2.R322_v20061207..jar
5fa4c000-5fa50000 r--s 00000000 03:02 2175832 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi.uti l_3.1.100.v20060601.jar
5fa50000-5fa9e000 r--s 00000000 03:02 2175838 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.apt. core_3.2.1.R32x_v20060822-2100.jar
5fa9e000-5faa1000 r--s 00000000 03:02 2175840 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.juni t.runtime_3.2.0.v20060605.jar
5faa1000-5ffda000 r--s 00000000 03:02 2175841 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform .doc.user_3.2.1.R32x_v200608101155.jar
5ffda000-6180d000 r--s 00000000 03:02 2175845 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform .doc.isv_3.2.2.R32x_v20070115.jar
6180d000-6182c000 r--s 00000000 03:02 2175846 /home/agupta/eclipse3.2/eclipse/plugins/com.jcraft.jsch_0.1. 28.jar
6182c000-6182f000 r--s 00000000 03:02 2175847 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.core .manipulation_1.0.1.r321_v20060721.jar
6182f000-61e0e000 r--s 00000000 03:02 2175851 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.doc. user_3.2.0.v20060605-1400.jar
61e0e000-61e1b000 r--s 00000000 03:02 2175852 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.osgi.ser vices_3.1.100.v20060601.jar
61e1b000-6235d000 r--s 00000000 03:02 2175854 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.doc. isv_3.2.1.r322_v20070109.jar
6235d000-623e2000 r--s 00000000 03:02 2175860 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .core_3.2.2.M20061205.jar
623e2000-623f1000 r--s 00000000 03:02 2175866 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ssh2_3.2.1.M20061205.jar
623f1000-62408000 r--s 00000000 03:02 2175867 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.prese ntations.r21_3.2.0.I20060605-1400.jar
62408000-626e5000 r--s 00000000 03:02 2175868 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.pde.doc. user_3.2.1.v20060816-0800.jar
626e5000-6275e000 r--s 00000000 03:02 2175870 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.update.u i_3.2.2.R32x_v20070111.jar
6275e000-627bf000 r--s 00000000 03:02 2175872 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.ui_ 3.2.0.v20060602.jar
627bf000-62804000 r--s 00000000 03:02 2175874 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jface.da tabinding_1.0.0.I20060605-1400.jar
62804000-6284b000 r--s 00000000 03:02 2175875 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.navig ator_3.2.1.M20060913-0800.jar
6284b000-62858000 r--s 00000000 03:02 2175877 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.team.cvs .ssh_3.2.1.M20061205.jar
62858000-62871000 r--s 00000000 03:02 2175879 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.navig ator.resources_3.2.1.M20060906-0800b.jar
62871000-628ad000 r--s 00000000 03:02 2175889 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ltk.core .refactoring_3.2.1.r321_v20060823.jar
628ad000-628c3000 r--s 00000000 03:02 2175892 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.ui.views .properties.tabbed_3.2.1.M20060830-0800.jar
628c3000-628c7000 r--s 00000000 03:02 2175894 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.help.app server_3.1.100.v20060602.jar
628c7000-628d6000 r--s 00000000 03:02 2175897 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.apt. ui_3.2.1.R32x_v20060822-2100.jar
628d6000-628d9000 r--s 00000000 03:02 2175903 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.jdt.juni t4.runtime_1.0.1.r321_v20060905.jar
bfe00000-bfe03000 ---p 00000000 00:00 0
bfe03000-c0000000 rwxp ffe04000 00:00 0
VM Arguments:
jvm_args: -Xms40m -Xmx256m
java_command: /home/agupta/eclipse3.2/eclipse/./startup.jar -os linux -ws gtk -arch x86 -launcher /home/agupta/eclipse3.2/eclipse/./eclipse -name Eclipse -showsplash 600 -exitdata 258800c -vm /home/agupta/src/javaLinux1.5.0_05/bin/java -vmargs -Xms40m -Xmx256m -jar /home/agupta/eclipse3.2/eclipse/./startup.jar
Environment Variables:
JAVA_HOME=/home/agupta/src/javaLinux1.5.0_05
PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/usr/local/ mozilla/:/home/agupta/bin:/home/agupta/src/javaLinux1.5.0_05 /bin:/home/agupta/src/Tools/apache-ant-1.5.3-1/bin:.
LD_LIBRARY_PATH=/home/agupta/src/javaLinux1.5.0_05/jre/lib/i 386/client:/home/agupta/src/javaLinux1.5.0_05/jre/lib/i386:/ home/agupta/src/javaLinux1.5.0_05/jre/../lib/i386:/home/agup ta/src/Tools/DBPasswordManager/linux/db_pwd_manager.so:/home /agupta/src/WebEng/monthly/javaweb/lib/linux/libjava_pwd_man ager.so:/usr/local/mozilla/
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x2ebc30], sa_mask[0]=0xfffbfeff, sa_flags=0x14000004
SIGBUS: [libjvm.so+0x2ebc30], sa_mask[0]=0xfffbfeff, sa_flags=0x14000004
SIGFPE: [libjvm.so+0x25e6c0], sa_mask[0]=0xfffbfeff, sa_flags=0x14000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00001000, sa_flags=0x14000000
SIGILL: [libswt-mozilla14-profile-gcc3-gtk-3236.so+0x6b26], sa_mask[0]=0xfffbfeff, sa_flags=0x04000000
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x260a10], sa_mask[0]=0x00000000, sa_flags=0x14000004
SIGHUP: [libswt-mozilla14-profile-gcc3-gtk-3236.so+0x6b26], sa_mask[0]=0xfffbfeff, sa_flags=0x04000000
SIGINT: [libswt-mozilla14-profile-gcc3-gtk-3236.so+0x6b26], sa_mask[0]=0xfffbfeff, sa_flags=0x04000000
SIGQUIT: [libswt-mozilla14-profile-gcc3-gtk-3236.so+0x6b26], sa_mask[0]=0xfffbfeff, sa_flags=0x04000000
SIGTERM: [libswt-mozilla14-profile-gcc3-gtk-3236.so+0x6b26], sa_mask[0]=0xfffbfeff, sa_flags=0x04000000
--------------- S Y S T E M ---------------
OS:Red Hat Linux release 9 (Shrike)
uname:Linux 2.4.20-8 #1 Thu Mar 13 17:54:28 EST 2003 i686
libc:glibc 2.3.2 NPTL 0.29
rlimit: STACK 8192k, CORE 0k, NPROC 7168, NOFILE 1024, AS infinity
load average:0.07 0.04 0.00
CPU:total 1 family 15, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 1022304k(13788k free), swap 1044216k(989800k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_05-b05) for linux-x86, built on Aug 26 2005 16:24:31 by java_re with gcc 3.2.1-7a (J2SE release)
--------------010402070208070609020207--
Re: Crashing on Linux [message #313299 is a reply to message #313269] Mon, 12 March 2007 13:12 Go to previous message
Hi-
Can someone tell me what reconnended vm parameters I should be using
when running eclipse 3.2.2 on linux ?
Thanks!
Anima.
Anima Gupta wrote:
> hi -
> Any clues?
> thanks!
> Anima.
> # C 0x00010206
> Registers:
> 0x000101f6:
> C 0x00010206
> Other Threads:
> Heap
> Dynamic libraries:
> 5faa1000-5ffda000 r--s 00000000 03:02 2175841 /home/agupta/eclipse3.2/eclipse/plugins/org.eclipse.platform .doc.user_3..2.1.R32x_v200608101155.jar
> VM Arguments:
> LD_LIBRARY_PATH=/home/agupta/src/javaLinux1.5.0_05/jre/lib/i 386/client:/home/agupta/src/javaLinux1.5.0_05/jre/lib/i386:/ home/agupta/src/javaLinux1.5.0_05/jre/../lib/i386:/home/agup ta/src/Tools/DBPasswordManager/linux/db_pwd_manager.so:/home /agupta/src/WebEng/monthly/javaweb/lib/linux/libjava_pwd_man ager..so:/usr/local/mozilla/
> SHELL=/bin/bash
> DISPLAY=:0.0
> Signal Handlers:
Previous Topic:Automatic conflict resolution by "Team" plugin?
Next Topic:Newbie question: Having trouble figuring out table selections
Current Time: Tue Dec 02 18:14:37 EST 2025
Powered by FUDForum. Page generated in 0.04377 seconds
