Home » Eclipse Projects » Eclipse Platform » Customize Wizard dialog/ Wizard
Customize Wizard dialog/ Wizard [message #312924] Mon, 26 February 2007 01:04 Go to next message
Originally posted by: priya_kothari.persistent.co.in
Is it possible to add custom buttons to the wizard page along with
Back/Next/Cancel/Finish?
My plugin requires to add couple of buttons on a wizard page.
TIA
~Priya
Re: Customize Wizard dialog/ Wizard [message #312926 is a reply to message #312924] Mon, 26 February 2007 04:39 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Yes it's possible. When you extend WizardPage you have to overwrite
method IDialogPage#createControl(Composite parent)
In this method you can create all the controls, which you want to exist
on your wizard page, so you can add any button you want.
Hope this helps :)
Jakub Jurkiewicz
Priya napisał(a):
> TIA
> ~Priya
Re: Customize Wizard dialog/ Wizard [message #312929 is a reply to message #312926] Mon, 26 February 2007 04:56 Go to previous messageGo to next message
Thanks a lot, it did help. One more question, Can i add them next to Next /
Cancel - I mean in same Row?
"Jakub Jurkiewicz" <jakub.jurkiewicz@gmail.com> wrote in message
news:eru9tc$pt8$1@utils.eclipse.org...
> Yes it's possible. When you extend WizardPage you have to overwrite method
> In this method you can create all the controls, which you want to exist on
> Hope this helps :)
> Jakub Jurkiewicz
> Priya napisa
Re: Customize Wizard dialog/ Wizard [message #312930 is a reply to message #312929] Mon, 26 February 2007 05:19 Go to previous message
I'm afraid you can't or at last I didn't hear about such possibility.
If somebody knows how to do this please let us know.
regards,
Jakub Jurkiewicz
>> Hope this helps :)
>> Jakub Jurkiewicz
>> Priya napisał(a):
>>> Hi,
>>> TIA
>>> ~Priya
Previous Topic:Removing Resources perspective and other default IDE options in RCP
Next Topic:How to find out users write permissions ?
Current Time: Sat Nov 08 11:35:03 EST 2025
Powered by FUDForum. Page generated in 0.03469 seconds
