Home » Eclipse Projects » Eclipse Platform » cvs fetch error
cvs fetch error [message #312393] Thu, 08 February 2007 10:24
Sorry to keep posting with problems..
Am trying to get my feature and its plugins from CVS using 3.2.1 on Linux
and
an SSh connection to CVS server. I have a map file in my build project.
When I run the build the build fails with the message
"the document structure must begin and end within the same entity".
This is because the generated fetch_<myfeature>.xml file is incomplete -
it has a fetch.element target but fetch.plugins is incomplete.
A Retrieve.xml file is also made with the cvs commands to export some, but
not all of the files in my feature project. Running this works fine, the
files come out of cvs so it is not a cvs configuration problem.
If anyone has any suggestions, would be very grateful, else I'll just
write something myself in custom.xml.
Richard
Previous Topic:Problem catching event when importing an existing project into workspace
Next Topic:Expanded vs Unexpanded bundles
Current Time: Tue Jul 22 13:57:11 EDT 2025
Powered by FUDForum. Page generated in 0.03449 seconds
