Home » Eclipse Projects » Eclipse Platform » Extension Point question
Extension Point question [message #312209] Fri, 02 February 2007 15:58 Go to next message
Originally posted by: vb.prismtech.com
I have declared an extension point in my plugin. In the schema (.exsd) file,
I specify an Interface that the
user of the extension point must implement.
I use this extension point from another plugin - and instead of implementing
the interface specified in the (.exsd),
i used some other interface ( by mistake ). But no error was thrown at
runtime. The class specified in the extension
point loaded even though it implemented some other interface . Am i missing
something or is the schema file never checked
at runtime. How can such a check be enforced ?
Re: Extension Point question [message #312213 is a reply to message #312209] Fri, 02 February 2007 17:38 Go to previous messageGo to next message
You can do something similar the following:
Interface yourObject = (Interface)
configurationElement.createExecutableExtension("YOUR_CLASS_ATTRIBUTE ");
or
Object yourObject =
if (object instanceof Interface)
Snjeza
Vikram wrote:
> Thanks
Light bulb and error markers overlapping [message #312478 is a reply to message #312209] Mon, 12 February 2007 07:34 Go to previous messageGo to next message
I remember changing a preference that made the light bulb and other
markers to the left of the line numbers in editors collapse into one. I
have to point at them for a second or two before they open so that I can
select one of them.
I can't remember how to change this back to the default. I looked
through the preferences with no luck. Any ideas?
Shahim
Re: Light bulb and error markers overlapping [message #312479 is a reply to message #312478] Mon, 12 February 2007 07:45 Go to previous message
Posted at the wrong place, sorry.
> select one of them.
> Shahim
Previous Topic:How do I get breakpoints to show in the ruler
Next Topic:Obsolete editor type hanging around
Current Time: Thu Jul 17 19:53:56 EDT 2025
Powered by FUDForum. Page generated in 0.03809 seconds
