Home » Eclipse Projects » Eclipse Platform » Path
Path [message #312123] Wed, 31 January 2007 11:35 Go to next message
Originally posted by: jkalinowski.microwavedata.com
Where does Eclipse get the system path and if its not the same, is there
a way to wipe this data and reinitialize it? Thanks.
Re: Path [message #312141 is a reply to message #312123] Thu, 01 February 2007 08:32 Go to previous messageGo to next message
What exactly do you mean by "system path"? Classpath or binary path?
Eclipse inherits the binary path just like any other executable. As for
classpath, Eclipse ignores the system classpath; each Project has its
own build classpath.
Hope this helps,
Eric
Re: Path [message #312142 is a reply to message #312141] Thu, 01 February 2007 09:10 Go to previous message
Eric Rizzo wrote:
>> there a way to wipe this data and reinitialize it? Thanks.
> Hope this helps,
> Eric
Yes I was asking about the system classpath. Eclipse set up I had was
still detecting Cygwin even though I had gotten rid of it a couple of
years ago but it still adds Cygwin into the path. I wasn't sure if it
just grabbed the information of the OS, even deleting the Registry entry
doesn't change the path. Thanks for you help
Jeremy
Previous Topic:Launch clears workspace before it checks for busy.
Next Topic:Loading same plug-in twice, different versions
Current Time: Sun Aug 31 18:32:05 EDT 2025
Powered by FUDForum. Page generated in 0.16772 seconds
